?????painted Valve Covers???????
Old Jul 7, 2007 | 11:49 AM
Vader 87's Avatar
Vader 87
Default ?????painted Valve Covers???????
Im thinking of getting my valve covers painted, can i simply try the local body shop or is there someone here on the forum that specializes?
Old Jul 7, 2007 | 12:09 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Are you asking about your Fuel Rail Covers (FRC's)? if you are then you may want to do a search on the topic. There have been several threads that either explain how to paint them yourself or posts of folks showing their painted FRC's. I did mine, nothing fancy, but I think they turned out pretty good.
Old Jul 7, 2007 | 12:10 PM
WayFastVette's Avatar
WayFastVette
You can try Auto Buffs... Links in my sig!
Vader 87's Avatar
Vader 87
Yes (brain fart), fuel rail covers is what i meant.
Old Jul 7, 2007 | 12:18 PM
66ratpower's Avatar
66ratpower
Default Painted Rail Covers
Just go by your local hardware store and pick up a can of Krylon Plastic Primer and a can of the color you want. Wash the covers with laundry detergent , rinse well and use scotch brite pad to scuff well. Clean both covers with alcohol and prime and paint following instructions on cans of paint. Cost , about $12.00 and 1hour of your time. Works great and no down time. Good luck.
Optimus_C5's Avatar
Optimus_C5
St. Jude Donor '12
If you want to have them done for you check out C5KIDD. He is a forum sponsor and I 've heard nothing but high praise for his work. Here's his link, which is also on the left side of the page.
http://www.c5kidd.com/
I think it's a great visual modification.
Old Jul 7, 2007 | 12:27 PM
Optimus_C5's Avatar
Optimus_C5
St. Jude Donor '12
Here's a few threads on the subject.
http://forums.corvetteforum.com/show....php?t=1649857
http://forums.corvetteforum.com/show...el+rail+covers
This should give you a good start on painted FRC's
Old Jul 7, 2007 | 12:52 PM
C5KIDD and Noel at Auto Buffs come to mind.
Old Jul 9, 2007 | 07:46 AM
dmoore's Avatar
dmoore
I had a fellow forum member send me directions on how to do it so it looks great! I am starting mine. Send me your email and I can forward the email I received on how to pain them on your own.
Old Jul 9, 2007 | 09:02 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You can do them yourself! Just get some VHT High temp paint and clean them real good primer and paint to liking!
Thanks,Matt
To ?????painted Valve Covers???????
