My automatic 99 coupe vs 03 M3
Old Jul 9, 2007 | 12:56 AM
hexane's Avatar
hexane
Default My automatic 99 coupe vs 03 M3
So I already know I'm running 13.2 @ 107 mph on my high mileage automatic C5. It has the 2.73 base gear. Well my "buddy" just got a 2003 M3 from his dad. It was for his HS grad present. So now he's all in my face, very arrogant and now telling me how much faster it is than his old 6 speed LT1 Camaro he used in HS. Now thinks he could "wipe me clean" with his new M3. He thinks he could cut into the 12s with it... Well... to settle the score we are planning to race in Bradenton next week. I do not wanna street race him of course because its illegal and I'm just itching for some predicted results. So what are the likely results, assuming he can drive? I did research and found out that car weighs 3400 lbs, has 333 hp - 7900 rpms, 262 ft-lbs of torque - 4900 rpms. Does 0-60 mph in 4.8 seconds...
Dee
Old Jul 9, 2007 | 01:24 AM
Whiteonrice's Avatar
Whiteonrice
Looks like the M3 has a little more weight and a little less horsepower. You have an auto all you have to do is point it. I think he will have a hard time unless he has done a lot of racing in that car.
Rick
Old Jul 9, 2007 | 02:19 AM
97vetteman's Avatar
97vetteman
It will be very close but I think you will win if you put down a 13.2 you have a trorque advantage even though hp is similar.
I had a run with a BMW Z4 M which is the same engine as the M3. This took place at the drag strip because street racing is not allowed on here. Although he got a slight jump on me at the start the Vette soon closed the gap at the top end of the track.
Old Jul 9, 2007 | 02:24 AM
hexane's Avatar
hexane
Rick
Last time I was rode in an M3 was about 4 years ago. And I thought it was way faster than anything I've ever been in. I'd hope I can take it, though my Vette is ranked as average on the 2007 sports car list. Seems to me like every "high sports car" nowadays runs very low 13s and better...
I've been seeing brand new EVOs in the track with a few bolt-ons run down lots of cars costing twice as much...
Old Jul 9, 2007 | 06:15 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I'm putting my money on your car. The M3's are quick, but I don't think you'll see it run a 13.2 quarter mile.
Old Jul 9, 2007 | 07:10 AM
themosjohn's Avatar
themosjohn
I've been seeing brand new EVOs in the track with a few bolt-ons run down lots of cars costing twice as much...[/QUOTE]
this may be true, but what is the price for having to be seen in one of those unsightly things. m3s are sharp no doubt. i guess i just don't care for the evos style at all.
Old Jul 9, 2007 | 07:23 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Your Buddy will have to start to mod his M3 and then you will have to as well after the race at the treack!
He'll loose and he'll start to make it faster out of sheer frustration! you'll want to keep up! Unfortunately it's part of having friends with cars!
Thanks,Matt
Old Jul 9, 2007 | 10:21 AM
M6 Vetter's Avatar
M6 Vetter
Remember to post the results
Old Jul 9, 2007 | 10:45 AM
Mr. Couture's Avatar
Mr. Couture
i took an M3 out plenty of times in my 04 coupe. It's an A4
Old Jul 9, 2007 | 12:11 PM
tk97's Avatar
tk97
I'm a member of the M3 forum as well (I like M3's too) so there is often a lot of talk over there about how many members think an M3 will outrun a C5. Yes, I do defend the C5's honour with pride .
My brother has a '01 M3 coupe, and yes it is quick. We haven't had a chance to line them up yet at the track, but he already concedes that my car will probably edge him out. I have a coupe MN6 with the more aggressive 3:42 rear end.
Its really all about the numbers. You weigh less, have more hp & torque. If there are any factors going against you its your 2:73 gears. He might get you out of the hole, so make sure your launch is damn near perfect.
Old Jul 9, 2007 | 12:17 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
If he just got it, I bet he isn't very good at driving it, yet.
Either way I would pick your C5 over the M3. I do like the M3s and they are pretty quick for what they are, but the weight and power difference he has and the fact that you are in a punch in go (less likely to miss a gear ) that is an advantage to you.
Keep us posted.
Micah
Old Jul 9, 2007 | 10:55 PM
hexane's Avatar
hexane
I drove it today and did every bit of 0-60 mph in what the C&D say, 4.8 seconds. Got it to 100 mph in 14 seconds and that it shifting it as fast as I can. I took it to 8000 rpm in every gear. Its a very quick car, but I'm afraid I'll probably still own him in the quarter since I can muster mid 13s and trap consistently at 107 mph. I can safely predict that car will run a 14.1 at 102 mph....
Old Jul 10, 2007 | 01:12 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
According to the numbers I've found....stock he should run around 13.4 at 102 MPH. Not the numbers you're turning, so you have the edge there. Plus, those numbers are taken from times with professional drivers. So, unless he has lots of hours behind the wheel on the strip, point your car straight, turn a good re-act time, and smile.
Old Jul 10, 2007 | 01:16 AM
sneakelman's Avatar
sneakelman
Here's some interesting reading for you guys
http://albeedigital.com/supercoupe/a...0-60times.html
Old Jul 10, 2007 | 05:43 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Old Jul 10, 2007 | 06:40 AM
I'd give you the edge, but not by a whole lot. M3s are quick and if he can drive, you very well could be neck and neck.
Old Jul 18, 2007 | 08:05 AM
hexane's Avatar
hexane
My buddy's M3 ran a best of 14.281 @ 101.802 mph. His 60' was 2.011.
Eighth mile, he ran 9.125 @ 82.264 mph
My stock auto C5 ran 13.259 @ 106.043. My 60' was 1.972.
Eighth mile, 8.461 @ 87.020 mph
All I did was mash the gas. Easy as pie!
To My automatic 99 coupe vs 03 M3
Old Jul 18, 2007 | 08:27 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
A whole second is like six r seven car lengths, he probably doesn't talk as much smack now huh?
Old Jul 18, 2007 | 08:38 AM
csexton's Avatar
csexton
Congrats
Chuck
Old Jul 18, 2007 | 10:02 AM
BanditSRT's Avatar
BanditSRT
LOL that's awesome. Good job!
By Michael S. Palmer | 2026-06-03 09:39:05
