Brake hubs
Old Jul 9, 2007 | 12:13 PM
Gmlover's Avatar
Gmlover
Default Brake hubs
I have a 00 vert. I'm about to replace the rotors and pads. In the helms manual, It says I need a hub cleaning kit. Is this kit really needed?
Old Jul 9, 2007 | 03:04 PM
WetteVette's Avatar
WetteVette
Old Jul 9, 2007 | 03:19 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Never did and I have never had issues.
Old Jul 9, 2007 | 03:23 PM
Last C5's Avatar
Last C5
Hub cleaning kit? You mean the stainless wire brush hanging on your wall? That's all you really need to do and don't get carried away and oil or grease the studs. They won't torque right if you do.
Old Jul 9, 2007 | 03:30 PM
spider94r's Avatar
spider94r
Never heard of such a thing and agree with the wire brush. I like to put a little anti-seize on the back of the rotor where it meets the hub to impede corrosion back there. I also usually paint the rotor hats front and back with some black engine paint.
Old Jul 9, 2007 | 03:41 PM
rws.1's Avatar
rws.1
I used a wire brush and brake clean... It cleaned up the hub real well.
Like spider 94r I also put antiseize on the back of the rotors surface that mates with the hub.
Old Jul 9, 2007 | 03:51 PM
BATM4N's Avatar
BATM4N
Not unless you want to go out and waste money for absolutely no reason.
Old Jul 9, 2007 | 05:02 PM
rws.1's Avatar
rws.1
I mean to add that you do not need new bracket bolts or caliper pin bolts either... just clean them with a wire brush as well.
Old Jul 9, 2007 | 05:27 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Don't forget the Loctite!
I agree with rws.1
I use a little drop of loctite on the caliper mounting bracket bolts and the caliper bolts. Never hurts.
Bob K.
To Brake hubs
