[Z06] Battery Drain?? Need Your Help!!
Over the last few days:
1. Windows rolling up slowly
2. Clock not keeping time
3. Code tripped for "service active handling" and "traction control"
4. When applying brakes, headlights would dim
5. Sometimes a hard start
At this point, I hooked up the volt meter. With the engine off and the A/C on, headlights on, radio on, etc (means by which to drain battery) the battery still showed 12.xx volts. Then I started the engine with all of these things going and it moved up to 14.xx volts.
This Morning:
1. No power what so ever. No lights in car, engine not turning over.
?????SO, what is going on????? The battery seems fine, but even when the car is off, there is a drain somewhere. Any idea where this mysterious drain is coming from? PLEASE HELP!!!
THANKS!
Typical when a battery drops a cell.
I dropped the car off at the dealer this morning and after running some initial tests, they stated that there is a "draw" or a "short" coming from somewhere that is draining the battery.
Car only has Halltech intake, Borla Stingers, C6 Z06 shifter...previous owner had wired the car for a radar detector as well.
I'm thinking the short is coming from the air intake electrical connection, where the c6 Z06 shifter was installed, or the wiring for the radar detector.
Any other thoughts???
Could the short be caused by a blown fuse somewhere? Seems that so many vette owners struggle with the "electrical demons"
http://forums.corvetteforum.com/show...hlight=battery
Assuming the battery passes then I would then check the charging system. At idle the electrical system should be at 14.7 volts (or near it). We should be able to load the charging system up to or close to the alternator's capacity (amp rating and still maintain 14.7 volts or so. (with the egine rpm at 2k).
Assuming the charging system passes I would then check the current draw of the starter motor (Again, using test equipment like the VAT-40)
Assuming the starting circut passes I would then check for excessive current draw by first disconnecting the output of the alternator (factor out faulty diodes) and then factor out secondary circuts (by pulling fuses).
Good luck!
Craig
