Id like to more about my Vette.
Id like a data check on vin #1g1yy22g3v5103000. I know the car was a lemon buyback but Id also like to know all there is to be known about it. Thanks Rick
PM SpongeVette or Gene Culley for a history check. If you just want more info. on the Corvette in general then you can go here. www.corvetteactioncenter.com
Here you go Rick, this is what info I can get working at the dealer.
VIN : 1G1YY22G3V5103000
VEHICLE INFORMATION
Merchandising Model : 1YY07 -1997 CORVETTE COUPE Warranty Start Date : 04/30/1997
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : RICHARD HIBBARD CHEVROLET, INC.
191 S INDIAN HILL BLVD
CLAREMONT , CA 91711-4993
(909) 624-4541
Selling Source : 13 - CHEVROLET
Site Code :
Business Associate Code :
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM N/A Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 04/30/1997 10 miles 04/30/2000 36010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 04/30/1997 10 miles 04/30/2003 100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/30/1997 10 miles 04/30/2005 80010 miles
36/50000 CALIFORNIA EMISSIONS 04/30/1997 10 miles 04/30/2000 50010 miles
84/70000 CALIFORNIA SELECT COMPONENT 04/30/1997 10 miles 04/30/2004 70010 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/03/2007 111832 # V1153 - 04006 - INSTALL HARNESS KIT - AUTOMATICS ONLY 88705 miles
07/16/2002 701828 B E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 52023 miles
07/02/2002 701575 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 52023 miles
11/09/2000 670377 B J0690 - PULLEY, ACCESSORY DRIVE BELT IDLER - REPLACE 40549 miles
11/09/2000 670377 # N6600 - WIRING AND/OR CONNECTOR - BRAKE SYSTEM/TRACTION CONTROL - 40549 miles
06/20/2000 663325 # H2505 - MODULE, ELECTRONIC BRAKE AND/OR TRACTION CONTROL - FOUR WH 36229 miles
06/20/2000 663325 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - REPLACE 36229 miles
06/20/2000 663325 # J0690 - PULLEY, ACCESSORY DRIVE BELT IDLER - REPLACE 36229 miles
06/20/2000 663325 # N0110 - BATTERY - ONE - REPLACE 36229 miles
06/20/2000 663325 # C2020 - SUNSHADE AND/OR SUPPORT - RIGHT - R&R OR REPLACE 36229 miles
06/20/2000 663325 # C3240 - HANDLE, FRONT DOOR INSIDE PULL - RIGHT - R&R OR REPLACE 36229 miles
05/09/2000 661096 # J0710 - PULLEY, CRANKSHAFT BALANCER - REPLACE 34037 miles
05/09/2000 661096 B K5180 - CABLE, SHIFT CONTROL - REPLACE 34037 miles
05/02/2000 660778 # K5180 - CABLE, SHIFT CONTROL - REPLACE 33760 miles
01/25/2000 656184 # D1780 - ACTUATOR, VACUUM DIAPHRAGM - DEFROSTER - REPLACE 29890 miles
01/25/2000 656184 # R3291 - MIRROR, OUTSIDE REAR VIEW - ELECTRIC REMOTE CONTROL - LEFT 29890 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
From what I see it had a crank pulley installed then a few accessory drive pulleys. Is that consistant with info you got?
Dave
VEHICLE INFORMATION
(909) 624-4541
Site Code :
CLAIM HISTORY
Dave
Start reading from the Claim History part.
I also noticed two shifter cables have been installed.
See the JO690 thats the harmonic balancer/belt idler. There are three of these labor operations indicating 3 repairs in the same close area. Also has 2 K5180 thats the shift cable.
Dave
Dave
Dave
Dave
Received 8,928 Likes
It also doesn't look like a buy back candidate as it only had 2 problems in the 3/36 warranty period and most of the other problems are minor and they were resolved in 4 service trips. The car has one more trip to the dealer for a three year old car than the average Toyota of the same age.
Bill
Bill
I agree with you Bill. There are 3 similarities with pulleys. But thats all. And Registration does say Lemon Law/Buyback on it. I just drove it 800 miles without a problem,well almost, got home and did my routine check and noticed driver side differential seal was blown. But that seems to be the norm on these sooner or later. Ah what nthe hell it has 90,000 plus on it.......
The first Texas owner had a title without the brand but both subsequent owners got the branded title. Not sure how that happened and can't see what the buyback was for, if it actually was a buyback. Did you ever run that to ground?
