Alignment Issue?
Old Jul 13, 2007 | 01:54 PM
J's Toy's Avatar
J's Toy
Default Alignment Issue?
I have a 2000 with 79k on the odometer. Here is the problem on the front passenger side tire it is wearing only on the inside of the tire. The other 3 tires wear evenly. This is my second set with only 15k miles on the entire set. Could it be the aligment or something more expensive?
Any advise would be appreciated.
Old Jul 13, 2007 | 01:57 PM
jbauch357's Avatar
jbauch357
That could be a problem with worn out parts on that corner, or an alignment issue. Take it to an alignment shop you trust and have them give it a good caster/camber/toe alignment on all 4 corners (I don't think you can do caster on the rear though). Make sure they check that everything is tight before they do any alignment work...
Old Jul 13, 2007 | 01:58 PM
02gt350's Avatar
02gt350
runflats?
Old Jul 13, 2007 | 01:59 PM
J's Toy's Avatar
J's Toy
Yes they are Run Flats. Goodyear OEMs
To Alignment Issue?
