jacking pads vs. jacking pads
Old Jul 13, 2007 | 08:02 PM
mcgilles's Avatar
mcgilles
Default jacking pads vs. jacking pads
Just looking for some info on the various types of jacking pads available out there. is any type known to be better or safer to use than the others? I've seen rubber types, billet aluminum types, and then the do it yourself style made out of hockey pucks. the rubber ones might be more resistant to falling off of jack stands. is such a thing ever an issue? I like to be twice as careful as I really need to be anytime a car is off the ground and I may be under it!
I think they are an essential part of a corvette owner's garage, but with the variety of styles and prices, I could use some guidance before opening the wallet!
thanks!
Old Jul 13, 2007 | 08:05 PM
Rogue Leader's Avatar
Rogue Leader
St. Jude Donor '08
thanks!
I have had both and I would highly reccomend the Billet ones. I had 3 out of 4 rubber pads FAIL on me (2 got cored and one actually split in half). Plus the billet ones are slightly thinner which makes it easier to get the jack under the car.
moserbe's Avatar
moserbe
I use the aluminum pucks. It fits into the hole in the lifting mechanism of the jack and into the original tie down holes of the car. No way that it's going to fall. Good luck in your decision making.
Old Jul 13, 2007 | 08:07 PM
jbauch357's Avatar
jbauch357
get yourself 4 hockey pucks and then pick up some eye-bolts that fit perfectly into the shipping slots and have a corase wood-thread. screw the eye-bolts into the middle of the hockey pucks until when you put the big end into the shipping slots and turn they lock the puck in place. now cut off the excess eye-bolt sticking out the bottom of the puck and you are done. this will both ensure that the puck will stay in place via the bolt, and it will conform both to the jack stand and your car without doing any damage. they hold in place so well that you can forget they are under the car and come back a month later to work on the car and they are magically still in place.... trust me, I've left them underneath more than one time...
VLVETTE's Avatar
VLVETTE
Make a set of these for under $20. I glued the pucks together with some JB Weld.
Old Jul 13, 2007 | 08:12 PM
jbauch357's Avatar
jbauch357
^^^ same thig I did but I only went a single puck thick.
Also FWIW I never jack the car up via the puck locations, only support it using the front 2 pucks with jackstands and under the rear crossmember with jackstands. I drive the front on ramps, jack up the front (under crossmember), lower front down on jackstands/pucks, jack up the back (via crossmember) and lower back down on jackstands/crossmember...
Old Jul 13, 2007 | 09:30 PM
RonJ's Avatar
RonJ
I've been using hockey puck lifting pads for several years with my hoist. They've seen lot's of use, I even hoist the car to wash the rocker panel area ..... at my age I can't bend over ... <G>
The pucks have never failed or slipped in any way!
RonJ ...
Old Jul 13, 2007 | 09:40 PM
hotwheels57's Avatar
hotwheels57
Buy the BMW plastic pucks, snap them into place and they'll always be there when you need them.
Old Jul 13, 2007 | 09:47 PM
rgtkst's Avatar
rgtkst
thats the ticket right there. i put them in and forgot about them untill it goes in the air. no issues with tire shops, no issues with dlrs, no issues what so ever. and around $30 for the set of four
Old Jul 16, 2007 | 01:26 PM
bighank's Avatar
bighank
Default Hockey Pucks
Made mine with 4 REAL hockey pucks ($2.00 ea) and 4 eyebolts and NUTS ($0.50 ea). Drill the hole thru the hockey puck (one is enough why in the world would you use 2?) counteresink for the nuts and use some red Locktite. Keep them in your trunk in one of the small compartments in case you need to jack up the car away from home. BIGHANK
Old Jul 16, 2007 | 02:33 PM
champ53's Avatar
champ53
Old Jul 16, 2007 | 02:44 PM
csexton's Avatar
csexton
Hockey pucks work just fine for me
Chuck
Old Jul 16, 2007 | 02:48 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Yup, that's what I did.
Old Jul 16, 2007 | 04:52 PM
C5starman's Avatar
C5starman
CI 7-8 Veteran
I went with the A&A Corvette (forum vendor) rocker rails. Don't use pads any more and they offer a lot of protection in daily driving.
Old Jul 16, 2007 | 05:07 PM
spider94r's Avatar
spider94r
I have the billet ones and they are fine, but I am now down to 3 because I ALWAYS forget to take them out when I am done. They fit loosely enough that they can fall out if you drive with them in place. I think I'll make some out of pucks next time.
Old Jul 16, 2007 | 09:33 PM
Plasticfan's Avatar
Plasticfan
Where can I buy these? TIA
Old Jul 16, 2007 | 09:39 PM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default BMW Pucks
At your friendly neighborhood BMW 'stealership'! They are so busy with the "BMW Tax" that they won't even see a lowly Corvette owner waltzing in and making a purchase!
To jacking pads vs. jacking pads
Old Jul 16, 2007 | 10:42 PM
redrider's Avatar
redrider
Highly recommend the lifting pucks from Elite Enginneering. High quality and they are great people to do business with.
www.eliteengineering.com
Old Jul 17, 2007 | 01:32 AM
DeeGee's Avatar
DeeGee
If you want quality these are the ones
I now have rocker rails so they cover the jacking holes but I could lift the car on those if needed. Must say, I normally lift it from the front or rear frame in any case.
Old Jul 17, 2007 | 06:42 AM
Get the ones from Elite Engineering. High quality product.
