Heads first or Cam first????
Old Jul 13, 2007 | 11:33 PM
DGW's Avatar
DGW
Default Heads first or Cam first????
Current: Stinger intake, ls6 mani, LG headers, Borla Stinger '00 MN6
Thinking about G5X3 Cam and AFR 205 heads, can't afford both at once, so what do I do first? Thoughts.....
Old Jul 13, 2007 | 11:39 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
Wait until you can afford both at the same time and you'll save ~$700 in the process(labor/retune). But, if I absolutely had to choose-definitely cam first, it will net you the most power.
Old Jul 13, 2007 | 11:40 PM
nickolbag's Avatar
nickolbag
Ideally save and wait until you can do both. If you must I say cam first.
Old Jul 14, 2007 | 12:29 AM
rkhegler's Avatar
rkhegler
Do both at once. Save $
Old Jul 14, 2007 | 01:00 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I agree with everyone else here. Do 'em both at the same time.
Patience Grasshopper . . . . . . . . .
I know, it's not easy.
Old Jul 14, 2007 | 09:09 AM
Paulg680's Avatar
Paulg680
CI 7-8-9 & 12 Veteran
Wounded Warrior Escort '11
I recommend the cam first. You get improved performance with the cool sound of a lopey cam. That's what I did an I'm very happy with it.
Old Jul 14, 2007 | 09:40 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Given this choice, I would do the heads first.
You will need dual valvesprings to run that cam. If you do the cam (only) first, you will need to swap the spings in your stock heads when the cam goes in.
If you put the heads on now, you will be all set when you do get the cam, and there will be very little labor done twice.
Old Jul 14, 2007 | 09:45 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Put both on the shelf and go with a blower
Old Jul 14, 2007 | 10:37 AM
M6 Vetter's Avatar
M6 Vetter
Just gotta be patience.... I know, it's not easy.
Old Jul 14, 2007 | 11:03 AM
02MillenniumVette's Avatar
02MillenniumVette
Old Jul 14, 2007 | 01:58 PM
Both at the same time would be best, but if only one can be done, do the cam.
Old Jul 14, 2007 | 02:07 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
CAM first if you can't do them both. CAM only cars have shown nice increases in both the power and torq departments. If you do go CAM only right now, you need to upgrade the pushrods and springs at the least. I would further recommend a new timing chain and at the least a LS6 oil pump - if you want to spend a few dollars more get a ported one. The springs and pushrods can always be transferred over to the new heads down the road.
Ideal world...do both at one time and MAKE SURE you get a good tune!!!
Micah
Old Jul 14, 2007 | 02:37 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I would personally do the cam first if given the choice but I did heads/cam both at the same time along with blower. I wanted that first hit to be the real one
Old Jul 14, 2007 | 02:43 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I am sure it was. Wanna race Nouman!?!
Old Jul 14, 2007 | 05:11 PM
CTD's Avatar
CTD
I am struggling with this as well, my thinking process says the heads. The under the curve power looks more gooder.
Old Jul 14, 2007 | 05:14 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Tom makes a good point here...with that size cam, you'll have to swap the springs on the heads anyway. Have patience and do them both at the same time. You'll be happier and save money on labor.
Old Jul 14, 2007 | 05:19 PM
randy814u's Avatar
randy814u
When this happens to me, I buy the parts as I can afford, then install them all at once. You will end up with less down time also.
To Heads first or Cam first????
