A/C issue
Old Jul 14, 2007 | 10:56 AM
atchuntman's Avatar
atchuntman
Default A/C issue
After my 98 vette sits in the sun all day it really never cools down until I am almost home (20 minutes), is that normal?? Also, the passenger side vents are blowing colder air than the drivers side. Both are set to 60. Thanks.
Old Jul 14, 2007 | 11:03 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I don't think either situation is normal - but I'm no expert on the the HVAC. My '98 blows ice cubes almost immediately - and I live in a place where outside ambient temps are 110+ in the summer.
Do you know someone that has gauges and the ability to take the pressures on the HVAC. It almost sounds like you are low on refrigerant.
Old Jul 14, 2007 | 12:08 PM
Grayeagle's Avatar
Grayeagle
I just went thru this a month or so ago with my black '98 coupe, passenger side was blowing lukewarm w/driver side blowin hot air with dial set at 60 ..it was just not doin it for A/C yanno?
Had a stealership recharge it.
Now.. I have temp control set at 79, because any cooler and it is *too* cold even when it's 110+ in the shade,
and my car sits outside all day, every day
(no garage or carport, jest driveway ..
..and they built a Wal-Mart concrete-o-porium right across the street so its HOT here!)
It takes half a block to get cooled down to where the interior fan starts winding down in speed, or about 5 minutes idling in the driveway.
If I set it to 60, I cant stand to be in the car for long.. it's COLD!
-Frank
Old Jul 14, 2007 | 12:27 PM
T VETTE's Avatar
T VETTE
Here in center of Kalifornia.
Old Jul 14, 2007 | 04:39 PM
DeeGee's Avatar
DeeGee
When I lived in vegas I'd set 60 and recirc on. The flow on the recirc was quite a bit higher than the external setting.
Failing that maybe a top up on the "A/C juice"?
Old Jul 14, 2007 | 04:45 PM
DBS99MagRedCoupe's Avatar
DBS99MagRedCoupe
I had similar symptoms on my 99. A quick trip to the shop for an A/C recharge took care of it. Also make sure the condensor is free of dirt and debris.
To A/C issue
