So, I have heard people saying they have changed from the 3.42 to the 4.10 gears, What exactly does this mean? Is it just a part you can put on? And you can do it to an A4 correct?
Thanks guys
What this means is you actually remove the stock gearing in the rearend of the car and replace it with a larger gear. A bigger gear will help with getting the power down, and getting better quarter mile times if you take the car to the track.
Yes, you can change the gearing in a auto car or manual. Replacing the gear isnt like changing oil. There is specific measurments and certain ways to make sure the gear is shimmed properly. Otherwise you will break it.
As others have said, what it means is that you are changing the rear differential gear. Definitely should be done by someone with experience in working on vettes, as they are not like other cars.
Thats what I thought it was, thank you again. I figured that a professional should install it I was just making sure, maybe I will have my project for the next summer
You should come down to Burger King some Saturday night. Shoot me a PM if you are interested...
IMHO 4.10's are a little much for an A4. A lot of people go with 3.73 or 3.90's with an A4. Your going to want to do a higher stall converter at the same time...
Peace
Chip
When I do end up doing this (next summer maybe) I will probably get the 3.90's not the 4.10's. What Burger King do you guys goto? My Saterdays are pretty busy but maybe if I get one free I'll be able to come by
