Help with wiring HIDs
also when i have the lights on it my volt gauge goes from 13.6 at idle to about 13.3, is that normal?
Ok maybe i should have read them, but i still want to get verification that its ok to double the size of the amp, also that the lights should draw that much power at idle ( havnet checked to see if alternator compensates although im sure it does )
Barry
Barry
That is the same problem that I had with the HID's that I pulled out of the car. You shouldn't just upgrade the fuse because the wiring is not designed to handle that type of load. Upgrading the fuse only is asking for electrical problems. You need to install a switching relay that is connected to the battery via a large guage wire; with a 20 amp fuse for protection. You can get the relays from any stereo shop with a pre-wired harness, or I can help you with the pin configuration. I chose to ditch the whole HID thing instead but I would be happy to help you in anyway I can. BTW, she looks good with Texas plates
Steve
Steve
Thats what i am nervous about, however after seeing at night WITH the hids, i gotta have them. I think i may go the route you suggest and set up a wire and relay with an independant fuse directly to the hid ballast. That way if i burn a wire its not part of the wiring harness. Just have to figure what i am going to hook the relay. Maybe ill just install a switch inside the car for the lights to come on??
On a side notl you need to send me that stereo stuff, ill even cover shipping
I'm going deep into my memory banks now, but I believe this is how the relay gets wired: terminal 30 - directly to the positive battery terminal (this should be a 10-12 guage wire with a 20 amp fuse)
Terminal 87- To the positive of the HID ballast
Terminal 86- To a solid body ground(this wire should be the same guage as the battery wire)
Terminal 15- Connect to the existing factory headlamp positive wire
You don't need to install a seperate switch at all.
That was straight from memory, the only thing I may be incorrect on is terminal 87-it should be the external tab opposite of terminal 30. If I am wrong, than that terminal would be 87a
This would work for a Bosch or Potter & Brumfield single pole double throw relay...Whew! I'm sweating now
As for the stereo equipment...
They might use more power, and a 20a fuse might be a good idea for startup, but a fuse won't limit power to the lamps until it blows. Until/unless that happens the fuse is NOT your problem.
Mine flicker occasionally and so far I've attributed it to low system voltage. It almost ALWAYS happens when my foot is off the gas coasting or idling.
Good Luck
Somewhere I thought I recall seeing someone say there is a 'break-in' on the ballasts and to expect that temporarily. The vendor told me if one of mine continued doing it, he would send another unit. I have not bothered with it as 90% of the time they both fire up just fine.
I did blow a 10 amp fuse on the right side straight away after the install, so went to a 15 amp and have had no problem whatsoever.
Instead of doing the whole relay bit, you can put an inline fuse just after the connector to the ballast and load that with a 15 amp fastblow, then a 20 amp at the fuse box. Much quicker, and equally as 'safe' as the load (if it blew the 15 amp) would be right at the source or at the farthest from the fuse box..
That was my concern but after having been on for an hour or more, when I come in to park, pop the hood, feel the wires and they are all fine.... It's the starting voltage of the ballasts, not the continuing load or so I have chosen to believe.
Good Luck
