Non-uniform tire pressures?
Old Jul 18, 2007 | 09:12 PM
AuburnShrink's Avatar
AuburnShrink
Default Non-uniform tire pressures?
I just had Non-run flats installed on my 1998 vette today. They are Kumho ASX and they ride fantastic!
My only problem is this: The installation shop told me I should run 35lbs in back and 45lbs in front due to the offset weight of the car. This does not make sense to me and it sets off my tire pressure sensors over and over.
Are they right?
If so, how do I stop the TPMS beeping from the front tires?
If wrong, what should the tire pressure be? The MAX on the tire says 51 lbs.
Thanks.
Old Jul 18, 2007 | 09:17 PM
csexton's Avatar
csexton
30 psi all around
Chuck
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Doesn't sound right to me....
Old Jul 18, 2007 | 09:36 PM
The tire shop is . Run the factory recommended pressures listed on the label on the door.
Old Jul 18, 2007 | 10:05 PM
R Devil's Avatar
R Devil
Originally Posted by csexton
30 psi all around
Chuck
plus I'd never go back there again.
Old Jul 18, 2007 | 10:34 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
There is no "offset weight" we are very close to 50/50
Old Jul 18, 2007 | 11:53 PM
jrose7004's Avatar
jrose7004
Go with 30lbs cold all the way around.
Old Jul 18, 2007 | 11:59 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
30 psi all around
Chuck
Old Jul 19, 2007 | 12:03 AM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
30 psi all around
Chuck
Amen to that. My tired heat up after simple city driving for 30 minutes and are up around 32-34 PSI, but the right side is always 1-2 higher than the left. But I had the people who did the oil change due the pressure at 30 and the DIC showed 31 right (front and back) and 30 left.
Old Jul 19, 2007 | 12:15 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
What would a tire shop know about tire pressures?.........NOTHING
Go by your Corvette's recommended door sticker!!!
30 PSI
Old Jul 19, 2007 | 12:19 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
St. Jude Donor '05-'06
Old Jul 19, 2007 | 12:31 AM
T VETTE's Avatar
T VETTE
OK we all agree on the tire pressure (30) and the tire shop is
Old Jul 19, 2007 | 01:31 AM
DeeGee's Avatar
DeeGee
and the tire pressusres are related to the car not the tire.
Old Jul 19, 2007 | 02:12 AM
blacksedan87's Avatar
blacksedan87
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Not a bit surprised the tire shop recommended 45psi in front. You will experience a horrible ride and premature tire wear....soon you'll be back to buy new tires.
As the others have advised follow the vehicle manufacturer's recommendation on optimal tire pressures. They spent a long time calculating and analyzing data to come up with recommendations that will give you the best treadlife, handling and ride characteristics. How much time did the tire monkey spend analyzing data before he made his recommendation?
Old Jul 19, 2007 | 02:29 AM
NOS500's Avatar
NOS500
30 psi cold all around works for me.
Old Jul 19, 2007 | 07:08 AM
AuburnShrink
Thanks so much guys!
I figure with 14 replies so far and NOT ONE person thinks this makes sense.....it is time to "release the air" and go back to 30 psi all around.
Thanks again...I love this forum.
Old Jul 19, 2007 | 09:18 PM
RonJ's Avatar
RonJ
30 psi cold takes the centre out of my Michelins. I'm trying 28 psi to get a more even tread wear.
RonJ ...
To Non-uniform tire pressures?
Old Jul 19, 2007 | 09:22 PM
Pecemkr's Avatar
Pecemkr
Old Jul 19, 2007 | 10:05 PM
b_pappy's Avatar
b_pappy
From: the GOCC are everywhere, even back from "band camp"
The tire shop has their head screwed in a pipe. Most people are happy with 30 all around as the factory suggests.
Bruce
Old Jul 19, 2007 | 10:09 PM
SilverScorp's Avatar
SilverScorp
I'll tag on another burning question: My tires have a Max pressure of 50psi. Will running them at 30 cold to be too low and potentially cause tread separation?
