Headlight shakes
Old Jul 19, 2007 | 12:20 AM
NVR_L8's Avatar
NVR_L8
Default Headlight shakes
My drivers side headlight shakes or bounces when I hit a bump in the rode any suggestions on tightening it up.
Old Jul 19, 2007 | 01:20 AM
DeeGee's Avatar
DeeGee
If you raise the headlights and back off to the parking position to kill the main beams
Take off the black shroud (3 screws
Take a look at the bolts thet hold the light in place and see if they're tight. I thinks its 3 bolts if I remember correctly. They screw into the plastic housing so don't over tighten them. If someone has done that in the past that may be the problem. If so, you may be able to fit an oversized bolt and fix it in better.
Old Jul 19, 2007 | 09:24 AM
rws.1's Avatar
rws.1
NVR_L8,
Is this before or after the install of your new HID's?
Old Jul 19, 2007 | 11:24 AM
NVR_L8's Avatar
NVR_L8
Default Before and after the HID's
Since the HID's where installed I notice it more (because of the bright lights).
Old Jul 20, 2007 | 08:52 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I noticed the same thing, except for my driver side headlight.
Old Jul 20, 2007 | 10:07 AM
StingR's Avatar
StingR
I had the same problem. I tightened the bolts up that attach the headlight to frame (x3) and it no longer shakes
Old Jul 20, 2007 | 10:37 AM
bioman's Avatar
bioman
My understanding is the the HID's weight alot more.... more mass...more jiggle...Pam Anderson effect.
To Headlight shakes
