Slam the Hood?
Old Jul 19, 2007 | 09:53 PM
YeloFevr's Avatar
YeloFevr
Originally Posted by YeloFevr
Am I the only one who does the "wrap shirt around hand" to press down on the hood???
Originally Posted by R Devil
Yes
Oh man...:o
11yellowgscpe's Avatar
11yellowgscpe
My 99 had a problem with the drivers side, I had to push on it after it was closed. My 03 works great from about 10".
Old Jul 19, 2007 | 09:57 PM
Always Red Dave's Avatar
Always Red Dave
Originally Posted by Yello95
I got mine new and I have never dropped it yet...I just lay it closed and push over the latches and it has worked perfect for 3 years now
I will let the next owner beat the hell out of the hood but I won't
When I mean slam it is more like a drop from 2 feet would never beat up on any part of my car. Definately a problem closing C5 hoods.
Old Jul 19, 2007 | 10:04 PM
spider94r's Avatar
spider94r
I've been slamming for years and it's never hurt anything. It won't close any other way. I thought that was normal! Guess I'll see if I can adjust it.
Old Jul 19, 2007 | 10:10 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
I just close mine. Works every time.
Old Jul 19, 2007 | 10:25 PM
Rocket02's Avatar
Rocket02
Default The best way to close your hood.
I close the hood very gently just until it starts to latch then I carry a 50lb bag of sand in the back which I toss right in the middle of the hood. Sometime is still won't close right and I just stand with one foot on each side of the bag and jump. That always works!! People are just amazed when they see me. I know, I know, they're probably thinking "Hey, what didn't I ever think of that!!". And......if you keep the hood wax really good, you can just slide the bag of sand down the front onto the ground. That way you don't have to pick it up and chance scratching the hood as you lift it off.
Old Jul 19, 2007 | 10:31 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Both of my sides latch from about 8 inches up and drop the hood. No Problem....
Old Jul 19, 2007 | 10:47 PM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by csexton
Alright folks, let's get our latches and bump stops adjusted
Chuck
Why does everyone just live with the problem instead of fixing it? Everything is not adjusted perfectly from the factory, even on a Corvette. If you cannot drop the hood from the center from 1-2 feet and have the hood latch on both sides, you need to adjust the rear hood bumpers down a little until they latch easily.
If you think you should never slam a Corvette hood, then you better not get a carbon fiber hood. They are so light that they will go back up if you let them go from any height, so you have to slam them down from the middle of the hood. They are not only light, they flex a lot.
Old Jul 19, 2007 | 10:58 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
The only things I slam anywhere near my vette are Mustangs
Old Jul 19, 2007 | 11:10 PM
silverbullit99's Avatar
silverbullit99
Try putting a little greese on the latches,,
Old Jul 19, 2007 | 11:12 PM
Mine latches fine if I drop it from about 12-18" up, but I usually just lower it gently down and push down on the latch area too.
Old Jul 19, 2007 | 11:14 PM
redrider's Avatar
redrider
FYI...the rubber stops for the hood are adjustable. Sounds like yours might be a turn or two too high preventing the hood from fully activating the latches on a reasonable drop. Just loosen the lock nut on the threaded stem under the rubber top and and lower the stem a couple turns and see if it helps.
Old Jul 19, 2007 | 11:17 PM
  #33
50vette03's Avatar
50vette03
Default Answer
My 03 did this and come to find out the latch on the inside of the fender was loose and the screw just needed to be tightened. Fixed it and never had the problem again. But then I sold it. I need another baaddd.
Old Jul 19, 2007 | 11:19 PM
  #34
LLVETTE's Avatar
LLVETTE
6 inch drop for mine. Never pops up after. Expensive hood and very expensive paint are just fine.
Old Jul 20, 2007 | 09:32 AM
  #35
kromberg's Avatar
kromberg
Stock hoods are OK to 'slam' a little, but aftermarket fiberglass hoods are a big no no
Keith
Old Jul 20, 2007 | 09:36 AM
  #36
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Chuck
I had to adjust one side of our coupe when I got it - it would not latch when I dropped the hood from a couple of feet.
Properly adjusted it will close and latch easily and dependably.
best regards -
mqqn
  #37
Tony Kataro's Avatar
Tony Kataro
Slam
To Slam the Hood?
Old Jul 20, 2007 | 09:43 AM
  #38
Joe0121's Avatar
Joe0121
St. Jude Donor '06
I just sort of let mine drop down on it's own from about 3 1/2 feet up and it latches perfectly every time.
Old Jul 20, 2007 | 09:59 AM
  #39
Robertelarkin's Avatar
Robertelarkin
Originally Posted by Always Red Dave
I slam mine from the middle of the hood or else I end up with one side not catching also.
Ditto..............
Old Jul 20, 2007 | 10:03 AM
  #40
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Bump stops are not the only adjustment -- the latch mechanisms can be moved around, too. If after adjusting the bump stops you don't like the hood/fender alignment, put the bump stops back to where the alignment is good and adjust the latches to match. Mine now latches both sides every time when dropped from less than a foot.
