Convertible Top Leak FIX???
Old Jul 21, 2007 | 08:48 PM
MedChoice Tony's Avatar
MedChoice Tony
Default Convertible Top Leak FIX???
Hi, is there a fix you can suggest if the convertible top is leaking through one of the seams?
Thanks,
TonyP.
Old Jul 21, 2007 | 10:46 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
If the seam is not separating I would suggest that you order some Ragtop top protector. I use it on my '02 and the top still looks great.
Old Jul 21, 2007 | 11:49 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I think he's referring to a water leak. I would think an upholstery shop would be a start.
Old Jul 22, 2007 | 03:20 AM
DeeGee's Avatar
DeeGee
Without breaking the seam even more it would be difficult to get any sealant into the joint. I would say a proper fix would be the best route.
Or ......... stop driving it in the rain
Old Jul 22, 2007 | 05:45 PM
FLACHUSNRET
I may be misunderstanding the problem, but if the water repellant has been removed from the fabric or seam due to detergent or friction, etc. then a paraffin based product like Raggtop is designed to coat the fabric finish and provide a surface that water will only bead up on rather than soak through.
Good luck in solving your problem.
To Convertible Top Leak FIX???
