I have a 2003 vert the driver power windows buttons don't work the driver or passanger but the passanger button works and the lock button on driver door unlocks but does not lock and the power mirror works the driver side but not passanger mirror and seat memory does not work I changed the module in the driver door that did not work and tested the switch now I'm stuck don't know what to do .
I'll post this link for you to follow also. My problem was identical to yours and I followed the methodology in this post to locate my problem. My solution ended up being identical to that in this post except that the "problem" connector in my case was inside the drivers door. Just takes some time to take everything apart and look at the pins. Good luck -------
I tried all that still nothing I went thought alll the connections and replaced the module in the driver door I checked the computer in the car and it said driver door no communication I'm stumped
If you have no comms have you tried pulling open the rubber boot in the door area and checking the connectors in there?
