How to enable backup lights at will?
Old Jul 26, 2007 | 12:10 AM
jbauch357's Avatar
jbauch357
Default How to enable backup lights at will?
I did a search and didn't find anything on this...
How would I go about turning on the backup lights any time that I wanted to, without actually going into reverse? I am assuming there is just a relay that I need to power on to accomplish this, then add a small switch inside the cabin and done deal?
Thanks in advance!!!
Old Jul 26, 2007 | 12:26 AM
jdmvette's Avatar
jdmvette
Night Owl for life
this can't end well...
Old Jul 26, 2007 | 01:04 AM
b98's Avatar
b98
not legal
Old Jul 26, 2007 | 01:31 AM
DeeGee's Avatar
DeeGee
Theres a wire that goes to the handbrake. When you put the e brake on it goes to ground and makes the circuit
But . White lights showing to the rear when you're travelling forward is illegal both in the US and the UK. It would confuse someone behind you into thinking that there's a car on their side of the road coming towards them. Dangerous in my view.
Old Jul 26, 2007 | 03:45 AM
WWK888's Avatar
WWK888
And why would you want to do this?
Old Jul 26, 2007 | 04:53 AM
ZShot's Avatar
ZShot
I've seen wannabe streetracing ricers do it. Please don't be one of them.
Old Jul 26, 2007 | 07:05 AM
HeadHunter1's Avatar
HeadHunter1
I have them set up on my truck with a single pole double throw switch-center off and a relay out back. This way I can put them in auto mode, off, and on all the time. This was done so I could hitch a trailer in the dark by turning on the lights back there without being in reverse.
To do this, you need a relay installed on the reverse light wiring and a constant power source for the lights. Cut the existing power feed for the lights and wire the light to the relay. You then run the trigger for the relay into the switch and attach it to the common terminal. The other two terminals on the switch get a feed which is hot all the time and one that only hot when the car is in reverse. Most likely the easiest source would literally be the wire that you cut out back to power the lights from the relay.
Again, as said before, it is illegal on the road and you will get a ticket if caught.
Old Jul 26, 2007 | 08:16 AM
jbauch357's Avatar
jbauch357
thanks for all the illegal and streetracing commentary, but that doesn't really concern me at the current juncture.
what I am looking for is what I need to change/add on the current vehicle to enable the reverse lights any time I want to. rumor has it that it's a somewhat simple addition/modification to the C5 that doesn't require a lot of additional wiring or hardware...
HeadHunter1 - thanks for the info on how you did it with your truck, I'll keep that method in mind.
To How to enable backup lights at will?
