Leak at tire pressure sensor....HELP
Old Jul 28, 2007 | 09:48 PM
vett79's Avatar
vett79
Default Leak at tire pressure sensor....HELP
I just had my new Z06 wheels put on my 98 Friday (sorry no pics) and tonight I get a low pressure notice on the left rear. I put a little soapy water around the valve stem and got slow bubbles. Can these be tightened from the outside or do I have to take it back to the tire guy to be tightened on the inside?
Old Jul 28, 2007 | 10:31 PM
my6thvette's Avatar
my6thvette
They tighten from the outside.
Old Jul 28, 2007 | 10:36 PM
RubberBill's Avatar
RubberBill
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
....but if the O ring on the inside is bad (i.e. cut or twisted) you need to take the tire back, break the bead, and pull the sensor. Not a big deal. I had to do it on mine. The concern is that the gum chewing kid at the tire place tears the bead on the run flat or screws up the rim.
Old Jul 28, 2007 | 10:39 PM
LoneStarFRC's Avatar
LoneStarFRC
They are tightened from the outside. They can't tightened from the inside.
Using an 11mm (or 7/16") 6 pt. deep socket, tighten it just a bit. If you don't have a torque wrench, don't crazy here as the torque value on those nuts is 106 inch pounds (or 12 Nm). The nuts are aluminum so you can booger one up pretty easy and damage it from overtightening.
Check it with soapy water again after you're finished. If you still keep having trouble, take it back to your tire guy and have him remove the tire again and check the small o-ring on the inside located on the stem itself. Maybe it's cut or damaged.
If tightening it takes care of the problem, go to an auto parts store and buy a small tube of Loc-Tite green. Apply a couple drops at the stem/nut area. The green is designed to be used on assembled fasteners and will wick it's way into the threads to keep the nut from loosening in the future. Works great.
HTH,
Robert
Oldvetter's Avatar
Oldvetter
For generation II sensors (2001 -2004) it is 62 INCH-Pounds, not Foot-pounds.
Tourque is higher for Generation I sensors (1997-2000), it is 106 inch-lbs.
Old Jul 28, 2007 | 10:40 PM
RA91925's Avatar
RA91925
Not certain about the 1998 sensors. On my 2001, I would tighten it some from the outside. If the problem is a loose nut, it won't take much torque to get a good seal. If snugging it up a bit doesn't stop the bubbles, you might want to let the tire installer take a look.
If they look inside, check the seal on the sensor and also check the face surface in the wheel where the sensor seats. Any burrs or a spotface that isn't flat (unlikely problems) might make it hard to get a good seal. Although unlikely to happen to you, I sent a wheel back recently because it had a burr on the inside face of the valve stem hole. Vendor thought I was nuts.
Wow. In the time it took me to type this, several others already gave you good answers. At least everyone is consistent.
Old Jul 28, 2007 | 11:07 PM
RubberBill's Avatar
RubberBill
with all having been there.
Old Jul 29, 2007 | 03:41 AM
DeeGee's Avatar
DeeGee
Good advice
Did you fix the leak?
Old Jul 29, 2007 | 09:07 AM
vett79's Avatar
vett79
I believe it worked. I'll check periodically, but for now no bubbles! I knew you guys would have advice. I had a C3 for 12 years and became able to tackle anything based on good advice from the forum. I'm still a little nervous on my C5 but as usual you all came through.
I do need to say a good word about the dealer that did the switch. Bud's Chevy in St. Mary's Ohio switched the tires and sensors and balanced with stick on weights for $140 which I thought was reasonable. They are a large Corvette dealer so I was impressed with the care they used. They let me go back to service any time to observe and had 3 other Vettes in the shop at the same time.
Thanks for the help !
Mike
Old Jul 29, 2007 | 09:13 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Just a note - it is possible that the 'leak' is temporarily 'fixed' by the tightening (to spec) of the outside connector.
However - many times the "O" ring has either deteriorated over time, or has been overtightened in the past.
If the above has occurred it will be necessary to remove the existing "O" ring (requires disassembly of tires from wheels) and replacement of same.
In the future - always replace the "O" rings when changing wheels or tires. Always require the installer to tighten the 'nut' to OEM specs.
Old Jul 29, 2007 | 09:40 AM
Vega$Vette's Avatar
Vega$Vette
You always have to keep your nuts tight to keep from leaking.
Old Jul 29, 2007 | 09:44 AM
rare-72's Avatar
rare-72
When I replaced my wheels, I used the green A/C "O" rings in the same diameter as the originals to install the sensors. They are a little thicker, and I have not had any leak problems.
Old Jul 29, 2007 | 11:03 AM
csexton's Avatar
csexton
I 'm glad mine aren't leaking
Chuck
Old Jul 29, 2007 | 11:35 AM
LoneStarFRC
Chuck
And now you won't have to take those nasty penicillin shots!
Old Jul 29, 2007 | 11:49 AM
gpotski's Avatar
gpotski
Mike
I bought my Vette from Bud's, and I am happy with their service too.
I took my new Goodyear GS-D3's to Buds to have them mounted and road-force balanced.
I put in new tire pressure sensors at the same time. I picked up a second set of 2004 rims off the forum for sale.
They have a great Corvette showroom!
Old Jul 29, 2007 | 12:46 PM
csexton's Avatar
csexton
I hate those things
Chuck
Old Jul 29, 2007 | 07:10 PM
vett79's Avatar
vett79
I didn't have an inch pound torque wrench so I ended up taking the nut to solid to get the leak to stop. Any issues with that?
Old Jul 29, 2007 | 09:40 PM
jpl99vert's Avatar
jpl99vert
vett79 Did the same thing last week, put Z06 wheels on my 99. Discount tire had to install thicker o rings to stop the leak. I think there's a ridge where the early sensors do not seat right on the Z06 rims. Thicker oring solved the problem
To Leak at tire pressure sensor....HELP
