Ponder This!
I can turn my Driver's side to 60 and the passenger side "all the way red" and it keeps blowing cold air, turn drivers side up and the passenger side heats up. Give it a try, see if you get different results.
No wonder the passenger **** has no digital numbers.
The Illusion of choices
$45k truck has dual climate control and $54k Corvette doesn't. This to me is Bass Ackwards
Heres what the manual says. The 2 degrees came from my fuzzy memory banks froma previous thread. At 60 the temperature is locked to the digital setting.
Passenger Temperature Offset
The PASSENGER **** changes the temperature on the
passenger’s side of the vehicle. When the **** is in the
12 o’clock position, the passenger’s temperature is the
same as the driver’s. Turn the **** clockwise for warmer
air on the passenger’s side, counterclockwise for cooler
air. If the driver-set temperature is set at 60F (16C) or
90F (32C), turning the passenger **** has no effect
because the system is locked at a maximum setting.
Heres a pic from Joe1021s HUD fit. Confirms what you say. PM E-T, Patches or Bill Curlee and see if they know
