Pull key & CLB question
Old Jul 29, 2007 | 10:31 AM
VinnyT's Avatar
VinnyT
Default Pull key & CLB question
Okay, first time I got this message. Car was running while the message displayed. Went into reverse, fuel cut off. Started right back up with no problems. Now, I did LOTS of searching, but one issue wasn't resolved.
If the recall was done(and it was done on mine, once) will the CLB work? I know it will keep the column from locking, but what about the fuel cut-off? What I have been reading, the fuel will still cut off, which is no help.
There has GOT to be a way around this stupid thing even after the recall.
BTW: I have cleaned the key pellet.
Thanks! V.
Old Jul 29, 2007 | 10:37 AM
Bob CTS's Avatar
Bob CTS
The CLB will work after the recall, however if you have had the K harness installed I would remove that and then install the CLB.
Old Jul 29, 2007 | 11:07 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Yeah, what he said!! The fuel will still cut off after the CLB is installed. I found this out the hard way. But from what I've read hear, you shouldn't have to worry about the light again if you remove the Harness K and then install the CLB. I am in the process of getting that done. Just waiting for the CLB to arrive.
Old Jul 29, 2007 | 11:10 AM
VinnyT's Avatar
VinnyT
Is there a link or pic of this K harness?
Old Jul 29, 2007 | 01:41 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
You will see a pic of the K harness here.
http://images.search.yahoo.com/searc...9c578&ei=UTF-8
Old Jul 29, 2007 | 01:52 PM
To Pull key & CLB question
