small rock chips
Old Aug 3, 2007 | 06:08 AM
lil vette's Avatar
lil vette
Default small rock chips
does anyone know the best wax, polish, or i heard about this thing called "The Stick" i can buy in color of my car.
what is best for small chips.
Old Aug 3, 2007 | 06:46 AM
Old Aug 3, 2007 | 07:04 AM
Bob CTS's Avatar
Bob CTS
Old Aug 3, 2007 | 07:23 AM
lil vette's Avatar
lil vette
Old Aug 3, 2007 | 08:05 AM
stormrider's Avatar
stormrider
VETFVER's method:
Fixing Paint Chips 101
At freeway speeds, you can’t go 100 miles without a rock bouncing off your car. If you have ever driven a motorcycle, you will know what it feels like to be hit by a rock.
To fix your paint ships, you will need a can of Turpentine, some touchup paint matching the color of your car, a toothpick, and cotton cloth.
1. Remove the cap on the can of Turpentine and put the cotton cloth over your finger and then put your finger over the opening and turn the can upside down. This will give you a dimes worth of Turpentine to work with.
2. The Turpentine on the cotton cloth is just enough to remove the wax around and in the chip.
3. Shake the touchup paint well and open the cap and take out the little brush.
4. Put a small chip sized drop on the end of your toothpick and tap it into the chip.
What you are looking for here is a bubble of paint in the chip. If you get some on your paint, don’t worry about it right now. After drying for 15 minutes the paint will shrink into the chip.
5. Repeat #1 before lightly in a fast motion back and forth begin to remove the paint that got onto the cars paint. What you are trying to do is just leave the paint in the chip. If you have made a mess, press harder and remove all the paint and start over.
6. Repeat this process a second time as you will need another round of paint in the chip to bring the paint level with the paint on your car.
Don’t worry about the Turpentine. It will NOT remove any factory paint on your car. The longer paint dries the harder it is to remove.
You will soon find that fixing a paint chip is not as hard as it sounds.
VETFVER
Old Aug 3, 2007 | 08:15 AM
OCDvetteman's Avatar
OCDvetteman
Now that's a master class on chip repair. Thanks
Old Aug 3, 2007 | 08:24 AM
lil vette's Avatar
lil vette
anyone ever here of this "Stick" wax or filler
Old Aug 3, 2007 | 08:56 AM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
Found at most auto stores. Colour Cure comes with a Chip Stick, a carnauba wax based colour stick, to fill in deep scratches and chips. Simply use the colour closest to your car's colour to help restore car to a like new look. Available in black, red, blue, white, silver and green.
Old Aug 3, 2007 | 09:31 AM
Bowhunter2001's Avatar
Bowhunter2001
Does it really work?
Old Aug 3, 2007 | 09:33 AM
jrose7004's Avatar
jrose7004
Hey stormrider, I feel like I've been to class!
Old Aug 3, 2007 | 09:48 AM
DavzC5's Avatar
DavzC5
It work great on my bright red C4. Haven't had need to use on my C5's yet.
Old Aug 3, 2007 | 09:50 AM
Bowhunter2001
Thanks. I will give it a try!
Old Aug 3, 2007 | 01:23 PM
V-man's Avatar
V-man
St. Jude Donor '08
Stormrider....thank you sir, I've got a chip on my Spiral Gray Metalic that I've been futzin with for months.....I'll try your trick......
Thanks V
Old Aug 3, 2007 | 01:38 PM
omarcoolguy's Avatar
omarcoolguy
not that well i used on my black vert its ok
Old Aug 3, 2007 | 01:40 PM
DBRASUE's Avatar
DBRASUE
NO!
Old Aug 3, 2007 | 02:20 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Old Aug 3, 2007 | 06:03 PM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
This stuff does not work. At least in black it doesn't. Tried it. Do not waste your money.
To small rock chips
Old Aug 3, 2007 | 06:14 PM
vettejeff's Avatar
vettejeff
That colord wax does a great job of turning your hands colors. I tried it on my truck and the only thing it colored blue was my hands.
Old Aug 3, 2007 | 06:49 PM
lovethyvette's Avatar
lovethyvette
thanks for the advice
Old Aug 3, 2007 | 07:37 PM
YelloMello's Avatar
YelloMello
the turtle color wax did help bring out the black on my old car.. but that stick didn't do Sh#$..
