[Z06] Car died...pull key, wait 10 seconds....
Old Aug 5, 2007 | 01:08 AM
Miguels's Avatar
Miguels
I get the same thing....it happens at times when you start the car....
pull the key out and wait...car starts....
This is a result of the recall for the Column Lock....the column does not lock though. Your car already probably has the CL Recall from the dealer. nothing to fear and no reason to spend $40.
Old Aug 5, 2007 | 01:27 AM
Under My Wheels's Avatar
Under My Wheels
Default Pull Key
Same thing here. Factory recall was done on mine and I still get the message. I just start mine like a diesel truck. I turn the key on to accessory and if the DIC comes up ok, I start the car. If I get the "Pull Key" error, I just turn it off and wait a few seconds before trying again. A pain in the rear for sure, but at least you are not starting the car and shutting it off, then re-starting it in front of a bunch of people watching you in the parking lot or in front of your neighbors...
Old Aug 5, 2007 | 10:55 PM
pb24dagrk's Avatar
pb24dagrk
I installed my CLB today
it was actually a b1tch and took me a couple hours
I ran into every problem imagineable
Old Aug 7, 2007 | 05:06 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Update: I decided to take my car to the dealership I'm very familiar with. To each their own, right? The service adviser called me back and said they re-programmed the PCM with updated software. They said it might act up again, if it does, bring it back in. If it does act up again, I'm going to buy the CLB.
Old Aug 7, 2007 | 06:56 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
I'm not sure if a CLB will work now that you had the dealer reprogram your PCM. I had the recall done after being stranded in my drive, and then got stranded again in the drive about a month later. I had the dealer restore the original program and then I installed the CLB. No more problems. You might research in the tech section and see if you'll have to get the new program reversed to be able to install the CLB when you get stuck again, believe me odds are you will get stuck again, it's just a matter of time.
Old Aug 7, 2007 | 08:24 PM
03 Z-oh-6's Avatar
03 Z-oh-6
I had an 02 z06 prior to the 04 and it had the column lock recall(dealer fix) before I bought it. I never had a problem with it in a year and a half, hopefully the same with the 04.
Old Aug 7, 2007 | 09:35 PM
Tact's Avatar
Tact
Good luck to you. The column lock fix by GM has been known to be a failure time and time again and it will hit you when you least expect it, but it's your choice. Just read all the horror stories, mine being one, in the sticky thread in the Tech section.
Old Aug 7, 2007 | 09:42 PM
03 Z-oh-6's Avatar
03 Z-oh-6
How come I got the "pull key, wait 10 seconds" and not "service column lock"? My sterring wheel never locked, the car just died, I started it rght back up. I asked this before, could it be something else??? The car is at the dealership right now, if it was something else, I'm sure they would have told me. Who knows...
Old Aug 7, 2007 | 09:57 PM
Tact's Avatar
Tact
They had many versions of the column lock fix, all being faulty, and each version did something different from the one preceeding each other. One of the versions, I believe it was version "C', would give you the message, kill the fuel, and not lock the column by the dealer removing the locking plate in the column. It was found that GM was installing the faulty K harnesses and there was also a belief that the actuators were causing some of the problems. Since GM could never find a "true" fix your best bet is to just get the CLB and be done with the faulty GM fixes.
Old Aug 7, 2007 | 10:03 PM
03 Z-oh-6's Avatar
03 Z-oh-6
The car had never been to any chevy dealer for service prior to me taking ownership, I looked at the service history report. I'll keep my fingers crossed. If it happens again, I'll figure it out from there. Thanks for all your info.
Old Aug 7, 2007 | 10:17 PM
Tact's Avatar
Tact
By you stating that your column never locked and the car stalled makes me believe someone (i.e. dealer) performed some version of the column lock recall previously, even though the history does not show it. Spending $50 on the CLB is cheap insurance you won't be stranded on the interstate late at night in "Crack-town". Best of luck to you.
Old Aug 7, 2007 | 10:21 PM
03 Z-oh-6's Avatar
03 Z-oh-6
I'm 99.9% sure if the dealer performed any warranty, especially a recall, it would show in the service history. Anyhow, I'll probably end up getting the CLB.
Old Aug 8, 2007 | 12:09 AM
  #33
procs2v's Avatar
procs2v
the clb wont work if it get shut the fuel right? My car has been in my garage for two weeks because of this problem, I had already taken it to the dealer. No luck there. I have tried everthing in the sticky and still no luck. I order a clb and hope I can figure out something.
Old Aug 8, 2007 | 12:33 AM
  #34
E.O.D.'s Avatar
E.O.D.
I KNOW you will. I'll be looking for your "Stranded due to Service Column Lock" thread on the other forum.
Old Aug 8, 2007 | 10:47 AM
  #35
Tact's Avatar
Tact
I believe you'll be OK, I just haven't read up on this issues since I installed my CLB a couple of years ago, i.e. no problems. I had understood if someone took their car into the dealer for the "latest" fix that the reprogramming would have to be reversed for the CLB to work, what exactly the dealer does I don't fully know. If it's just reprogramming the computer for the fuel to be shut off and the locking plate removed I think you'll be OK. Best bet is to contact Corvettes of Houston and talk to Tommy who is very familiar with the "latest" GM faulty fix.
Old Jun 17, 2009 | 09:11 AM
  #36
photoburger's Avatar
photoburger
2nd Gear
Default 5th time
I have a 99 Vette and this is going to be the 5th time for the "Service Column Lock' repair.
I have 135k on the daily runner.
My question is, can you install the CLB without getting the thing towed and repaired again?
Or do I have to have it repaired and then install the CLB?:
Old Jun 17, 2009 | 11:07 AM
  #37
CGartist's Avatar
CGartist
One of the fuses can be pulled to prevent this. Well...I think. THis happened to me once and my car guy pulled a fuse..turned the car on and the colum lock was gone. Now when it happens all I have to do is shock the steering wheel and it will unlock. I still need to get the bypass thingy but I keep putting it off.
To Car died...pull key, wait 10 seconds....
Old Jun 17, 2009 | 01:53 PM
  #38
photoburger
2nd Gear
Default wait 10 seconds
Hmmm, a fuse. The only fear I have is that the steering would lock up while driving...or is this possible?
As of now the steering is not locked up.
I found it ...it's fuse 25. Oh well I tried. It didn't work.
Old Jun 17, 2009 | 09:28 PM
  #39
MikeNMaxZO6's Avatar
MikeNMaxZO6
Originally Posted by SLO VETTE
Best mod I ever did--CLB kit. Takes about a half hour-45 min when taking your time.
Old Jun 10, 2011 | 01:40 PM
  #40
BRISLS1's Avatar
BRISLS1
St. Jude Donor '11, '14,’19
Can you wait for the lockout to happen before installing the bypass device? Or is it too late at that point?
I am not locked out of mine now (knock on wood), but curious if it would make sense to just shelve the bypass until it is needed.
