Is this Normal?
Old Aug 6, 2007 | 07:38 PM
ldimm's Avatar
ldimm
Default Is this Normal?
When I go to start my 04 CE Coupe it will crank for a few seconds before starting. My 96 would start as soon as I touched the key. Is it normal for the C5 to crank for awhile. I will say that it takes the longest after sitting overnight. Car is dead stock and low milage. ???
Old Aug 6, 2007 | 07:45 PM
lil vette's Avatar
lil vette
no
Old Aug 6, 2007 | 07:49 PM
81c3's Avatar
81c3
Right off the cuff. I'd say it points to the fuel system....maybe fuel psi regulator.
yaknow's Avatar
yaknow
Originally Posted by lil vette
no
Old Aug 6, 2007 | 07:52 PM
moserbe's Avatar
moserbe
Not normal.
Old Aug 6, 2007 | 08:11 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
This IS a good guess. The symptom sounds the same as mine when this happened (not the Vette)
Old Aug 6, 2007 | 08:14 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Do you let the fuel pump cycle before turning the key.
Sometimes when I get in a hurry, after the car has set a couple of days, and just crank it, it turns for a second or two.
It never ever does it if I let the fuel pump cycle first...
Peace
Chip
__________________
..................Click for
Old Aug 6, 2007 | 08:23 PM
T VETTE's Avatar
T VETTE
Peace
Chip
YOU NAILED IT Willfulone
Old Aug 6, 2007 | 08:27 PM
Dougzilla's Avatar
Dougzilla
with Willfulone also. Only takes a couple of seconds.
Old Aug 6, 2007 | 10:10 PM
Mine kicks right over.
Old Aug 6, 2007 | 11:57 PM
WetteVette's Avatar
WetteVette
Even with a brand new battery, and letting the fuel pump cycle, mine still cranks for a second or so before starting when cold. After it's warm, she starts up immediately.
Old Aug 6, 2007 | 11:59 PM
iced98lx's Avatar
iced98lx
I've never had to let the fuel pump cycle on mine.. It usually fires on the first pop... in fact, today it didn't for once and I had already let go of the key... woops!
Old Aug 7, 2007 | 12:13 AM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
I would have the dealer do a pressure test on the fuel rails. I had a similar problem, took a few seconds after leaving it overnight and would start right away when warm. Check it before closing, and then the next day. You will most likely find a drop in pressure.
Turned out there was a leak somewhere in the fuel tank area which caused the system to lose pressure.
Good luck
Old Aug 7, 2007 | 08:04 AM
ldimm's Avatar
ldimm
This morning I let the fuel pump cycle first and it did start quicker. I'll try this for awhile and see how it goes. In the long run I'll have the pressure checked next time at the Dealer. Thanks for the help!!!
Larry
Old Aug 7, 2007 | 09:06 AM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
My '04 starts with a resounding rock of the chassis when you hit the key. But, I do turn the key on, let my memory seat position, my gages cycle, and put my belt on before I hit the key. Correct me if I'm wrong, but don't '04's have a returnless, non regulated fuel system? Fuel pressure is regulated by the PCM, by pulsing the fuel pump as needed.
John
Old Aug 7, 2007 | 09:47 AM
CCA Corvette Parts
John
That is how I understand it.
Peace
Chip
Old Aug 7, 2007 | 09:51 AM
The Punisher's Avatar
The Punisher
Peace
Chip
same here
To Is this Normal?
Old Aug 7, 2007 | 10:10 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Peace
Chip
Chip,
Is this only the '04
Thought that from '99 on this was the case - could be wrong - have been so before
Old Aug 7, 2007 | 01:47 PM
CCA Corvette Parts
Originally Posted by AC54ME
Chip,
No you are correct, they changed from a fuel system that had a return
in 99. You will see D/S FRC's have two lines, and after 99 only one.
Peace
Chip
Old Aug 7, 2007 | 04:58 PM
regorih's Avatar
regorih
word
