[Z06] Titanium Mufflers??????
Old Aug 6, 2007 | 10:53 PM
vetsam's Avatar
vetsam
Default Titanium Mufflers??????
I'm not sure if this is a dumb question or not?? I've never seen anything that mentions whether or not the exhaust pipes welded to the mufflers are titanium also. Didn't know if you could actually weld steel to titanium? If anybody knows for sure I'd appreciate it if you could enlighten me. Thanks
Old Aug 6, 2007 | 11:06 PM
Jim M's Avatar
Jim M
St. Jude Donor '08
I don't know about welding steel to titanium, but I'm pretty sure the entire exhaust system from the over the axle pipes, including mufflers, and pipes and tips coming out of the mufflers are all titanium.
Old Aug 6, 2007 | 11:08 PM
lt1george's Avatar
lt1george
Default ti exhaust
100% titanium exhaust system,mufflers, pipes to over the axle. Tips are just a chrome flashing.Save the Wave.>George
Old Aug 7, 2007 | 12:29 AM
froggy47's Avatar
froggy47
All the way up to the cat?
Old Aug 7, 2007 | 07:26 AM
spdislife's Avatar
spdislife
That's my understanding...titanium from the cats back
Old Aug 7, 2007 | 07:41 AM
lt1george's Avatar
lt1george
no,not from the cats back.Here's a picture of the complete system.
Old Aug 7, 2007 | 09:58 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi folks -
Just like lt1george said - the only portion of the Z06 exhaust that is titanium is the rearmost section.
The H-pipe is stainless steel.
The "catback" portion, which is actually after the h-pipe, is all ti, from the flange to the tip.
best regards-
mqqn
Old Aug 7, 2007 | 12:32 PM
vetsam's Avatar
vetsam
Hey thanks guys, I appreciate the quick responses. The Forum comes through again!!
Old Aug 8, 2007 | 09:21 PM
QwickerRon's Avatar
QwickerRon
Corsa used to manufacture a complete Titanium system from cats to tips. No longer in production.
Old Feb 28, 2008 | 07:46 PM
RTTN 1's Avatar
RTTN 1
hey guys, i have a stupid question...
does anyone know what grade of titanium is used to construct the mufflers and pipes attached?
Old Feb 29, 2008 | 09:18 AM
Melsy's Avatar
Melsy
The H-Pipe is aluminized steel. I got a good look when they replaced mine under warranty with the TSB about exhaust "jingle".
Old Feb 29, 2008 | 05:57 PM
chevy406's Avatar
chevy406
Just to add another tid-bit of information. I installed a set of TI's on my FRC last night. They weigh 12½ lbs each. The Borla Stingers that I was replacing weighed 15 lbs each. My new TIs are much quieter, and my neighbors will appreciate that every morning.
Old Mar 1, 2008 | 07:01 AM
BlackZ06's Avatar
BlackZ06
http://www.corvettemuseum.com/specs/2001/exhaust.htm
http://www.americanmachinist.com/304...le/False/8095/
Old Mar 4, 2008 | 09:09 PM
ace996's Avatar
ace996
My old exhaust... with Ti bypass pipes welded in...sounded "exotic"...
To Titanium Mufflers??????
