Eckler's flip key problem
Old Aug 8, 2007 | 05:07 PM
LKYMN's Avatar
LKYMN
Default Eckler's flip key problem
I'm hoping someone out there can help me out. I purchased a flip key form Eckler's about 5 weeks ago. I just received it today and when went to the dealership where I bought my Vette to have them cut the key, I was told that they do not cut any key blanks that they do not sell.
I've called a couple of locksmiths and they do not cut keys that have the security chips.
So has anyone purchased a flip key and had the blank cut. If so, where did you go?
Old Aug 8, 2007 | 05:13 PM
Slotcar's Avatar
Slotcar
You spent how much to buy a car at a dealership and they won't cut you a key blank that they don't sell????.....
Did you talk to the general manager?
Old Aug 8, 2007 | 05:15 PM
Kale's Avatar
Kale
Is there only one gm dealership there?
Old Aug 8, 2007 | 05:16 PM
Vega$Vette's Avatar
Vega$Vette
Local Locksmith cut mine. No Problem just $5
Old Aug 8, 2007 | 05:46 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Old Aug 8, 2007 | 05:54 PM
b98's Avatar
b98
BOBBYS CHOPSHOP did mine.
Old Aug 8, 2007 | 07:25 PM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
I assume you purchased one of the "Corvette Key's"? Take is to Ace or Home Depot. The problem they will have is that with the key full extended it will not fit into their machine. Tell them to cut it with the key at a 90 degree angle to the case (not locked in the fully extended position). That will solve the problem ......
Make sure you get someone who knows how to run the machine before they start cutting, on mistake and the key is ruined. I use to carry those keys but the customer support surrounding the cutting part was a nightmare.
Good luck, hope I was able to help.....
Thanks,
Jim
Old Aug 8, 2007 | 09:06 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
I had mine cut at Home Depot. Took a couple of minutes and they didn't even charge me for it!
Old Aug 8, 2007 | 09:12 PM
Vega$Vette's Avatar
Vega$Vette
The Home Depot here refused because I did not buy it from them. I offered to pay and they came up with some stupid liability excuse.
Old Aug 8, 2007 | 09:14 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Bloody lawyers.
Old Aug 8, 2007 | 10:01 PM
robertp's Avatar
robertp
Home Depot did mine. No problem.
Old Aug 9, 2007 | 06:57 AM
A key shop should be able to cut it for you - sounds like you may need to expand your search area for a shop that will do it. Good luck.
Old Aug 9, 2007 | 11:38 AM
LKYMN's Avatar
LKYMN
Default Thanks for the suggestions
I just wanted to thank each of you for taking the time to respond. As of yet, I have not located anyone who will cut it. The Manager at the dealership where I bought the car is out until next week so I haven't given up hope there.
But in the meantime, I will try as some of you had suggested, and go to my local Home Depot and/or Ace Hardware and see what they could do. I haven't had any luck so far with Locksmiths (I thought that's what they do!!!)
I may not have this resolved yet but I'm a bit more confident now knowing that others have succeeded.
To Eckler's flip key problem
