Anyone try Permanent Jacking pucks?
Old Aug 8, 2007 | 09:51 PM
mkenyon's Avatar
mkenyon
Default Anyone try Permanent Jacking pucks?
Anyone try pucks that are always in like these?
NO EBAY LINKS.............please read da rules
or will they just hang down too low on a stock vette and look silly?
Old Aug 8, 2007 | 10:05 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
Looks like the same ones I bought from BMW ( Part # 51-71-1-960-752 ). You dont even notice them unless you are looking for them on the car.
Old Aug 8, 2007 | 10:15 PM
Thingobump's Avatar
Thingobump
ditto
Old Aug 8, 2007 | 10:50 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I got the BMW ones, they are great to have.
Old Aug 8, 2007 | 11:48 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
they look good, however I'd be concerned about speed bumps.
EE offers a frame rails with jacking pucks built in for roughly double the price.
Old Aug 9, 2007 | 12:59 AM
jrprich's Avatar
jrprich
No problem with the BMW pucks and speed bumps........mine have been in two years, no issues
Only $7.00 each from BMW
Old Aug 9, 2007 | 01:02 AM
DeeGee's Avatar
DeeGee
Cant see why you'd want to leave them fitted. Its a twist fit and takes about 2 seconds if you want to jack the car up. Leaving them in place you just run the risk of losing one.
BTW I have the elite engineering pucks. A few more $$$ but these things are a work of art. Great paperweight too.
http://www.eliteengineeringusa.com/jacking-pads.html
Mind you, they really are normally used as paperweights nowadays because I have rocker rails and you can jack from them if you need to.
Old Aug 9, 2007 | 08:28 AM
mkenyon's Avatar
mkenyon
I'm thinking of keeping them fitted in case I need a repair away from home. Or as most likely will happen, I'll totally forget to put them on before a scheduled repair.
Thx for the replies.
Old Aug 9, 2007 | 08:48 AM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
I use the BMW'S. No issues with morons who will not/don't know/don't care etc.
Old Aug 9, 2007 | 11:12 AM
Humanoid 2.0
The BMW ones snap securely into place, I highly doubt there is a risk in loosing one, and even scraping one over a speed bump given their location and low profile. It is usually the center of the rocker between the jacking points that hit the top of the speed bumps.
Also I have had my Vette to the dealer twice for warranty work, no worry that if I had the removable ones that they would use them since they are already on the car or that I remembered to have them with me. It is a great convenience to just have them on there all the time. And the price is cheep when compared to the removable machined AL ones.
Old Aug 9, 2007 | 12:02 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I bought those very ones your looking at. Like them a lot. The only thing that I had to remove them for was when the Service Column Lock light came on and the tow truck had to use those places to chain the car down. Other wise, they stay in and I have not had an issue with them. I do carry a flat blade screw drive with me though now just in case I need them off again.
Old Aug 9, 2007 | 01:02 PM
jpc0011's Avatar
jpc0011
Originally Posted by Thingobump
ditto
same here.
Old Aug 9, 2007 | 01:09 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
Try getting the Elite Engineering frame rails protectors. Have the jacking pucks built in and you protect the frame rails at the same time.
Old Aug 9, 2007 | 01:20 PM
Just ordered the BMW ones today. Should work just fine.
Old Aug 9, 2007 | 01:22 PM
mkenyon's Avatar
mkenyon
Where did you order the BMW issue through?
Old Aug 9, 2007 | 01:42 PM
mkenyon's Avatar
mkenyon
Old Aug 9, 2007 | 01:50 PM
jrprich's Avatar
jrprich
Just less hassle.........the BMW ones are invisible and stay put
To Anyone try Permanent Jacking pucks?
Old Aug 9, 2007 | 02:06 PM
jarsdad1's Avatar
jarsdad1
Bavauto.com
or BMP design
Old Aug 9, 2007 | 05:26 PM
mkenyon's Avatar
mkenyon
Awesome, BMW ordered and on the way!!!
Thanks folks
Old Aug 9, 2007 | 05:30 PM
hotwheels57's Avatar
hotwheels57
There's two BMW styles...the round one seem to be the most popular and allow for the rocker protection rails to be installed w/o interference later.
