[Z06] Missed 3rd (strange)?
On the other hand, anyone who prefers the advice of posters without relevant Corvette knowledge or experience is totally free to opt for their alternate paths.
Ranger
Ranger
You make very good points and have invaluable advice and knowledge, it just seems that almost all your post end with a link going back to your techniques?? What if his shifter is really broken?
Whatever happened in you own shifter issue from a couple months ago? As I recall you had no missed shifts with the stock shifter, but decided to install an aftermarket shifter anyway. You then had trouble, missing shifts with it at the drags. I recommended practice with the new shifter to embed muscle memory. I don't recall you ever posting the outcome.
Ranger
Ranger
BTW, I'm not intentionally debating you. I respect your knowledge and advice very much and have to say at times I even practice what you preach as well. I'm just posting my views. I mean, thats how we all learn a thing or two.
that's all i'm saying!And as a side note, I race cars at their limits. When you are at the limit, you do not make driver changes. You make changes to the vehicle. A shim is more definable, consistent, and reliable than judgement every time. I realize this is different than changing parts, but sometimes people do have their own style. You can make them change, do better, and have them hate their experience. Or you can adapt the parts to their style.
Ranger, maybe the stock Corvette was just designed around your body mechanics and sizings..... Every person is different.
. However, I notice a couple of times now, when shifting really hard to 3rd, I ended up between 3rd, and 5th somewhere. The shifter did go up in there, but nothing grabbing at all as if I had the clutch pedal in. Anyone ever have this happen, I am sure I will become more familiar with it, but should the shifter even go up in there? Thanks!Example of where I ended up wiht the shifter (x marks the spot)
1 3x5 R
2 4 6
I've been having a similar problem with my shifter also. Sometimes when doing a max acceleration run i do the 2nd to 3rd shift an my shifter will just not go into thrid, and i know almost certainly it's driver error, so i'm going to also practice my shifting from time to time.
On a side note: I have followed Rangers Clutch Fluid Procedure and so far my pedal sticks way less on hard acceleration then it was before. The clutch fluid still turns murky fairly quick but has been staying clearer for sometime now.
Patrick
Patrick
In post #8 I covered the issue of "shift refusal." You'll want to judge from your memory of the 2-3 event circumstances and aftermath whether it may have entailed a shift refusal, particularly if the launch involved notable slipping of the clutch (intentional or not). In that case the remedial action is (1) back to the clutch fluid and (2) a faster clutch release.
Ranger
To solve this problem: How to Improve Your Shifting
Ranger
So now on to the new problem/issue. I put a built 408 in the car, and expectations from myself and many others is quite high. First two passes on new set-up, missed 3rd gear. No grinding of gears, or slipping of the clutch (Aussie clutch), so I believe it was just a bad shift on my part totally missing the gate to 3rd. Next time I went out, same type of problem, had to granny shift and make very deliberate shifts, however, still got a best ever n/a run. But, there is so much left if I can regain my composure, and/or timing.
Ranger, or anyone, how can I regain my fast shifting ability? This is driving me crazy. How could I forget? After the winter lay off, I got one trip to the track before blowing my stock motor, then 4 months my car was down, could i lose the embedded shifting memory?
On the shifter, I replace my stock shifter after the first trip to the track. It just wasn't my style. I liked the short throw of the Hurst, and have made all fast passes with it.
Robert
Robert
Question to resolve is whether the issue is a lapse in muscle memory or a mechanical issue.
To that end, I'd suggest doing ten sets of the shifting drills daily for a week prior to your next track visit. And five sets in the lanes before each pass. See if that resolves the issue. If it doesn't, then I'd suggest resetting the shifter cradle. You've had the driveline apart often enough that it's possible an alignment issue has crept in.
I still do my shifting drills as a matter of routine. And raise the intensity further in racing season. And I always hammer five sets of the drills before making each pass. Goal is to ensure shifting is an absolutely automatic sequence, where each action is a cue to the next.
Tiger still spends a couple hours a day hitting ***** at the driving range, not just to keep the edge, but to improve it. I try to remember that.
Good luck Robert. Happy to chat by phone about this. Would like to see you getting everything possible out of the your new motor too.
Ranger
Ranger
Robert
(1) in gear. Fairly common with trashed trannies on LS1/2/6, but very uncommon on LS7. Involves bent/broken shift fork or blocker ring etc.
(2) when a locking screw in the cradle is missing or cross-threaded and askew.
Neither of these conditions are occasional. Once they strike they remain a persistent condition. Nothing akin to the symptoms described in the lead post.
Ranger
I didn't know once it's even slightly bent, that you would need two hands to get it out of every gear. If this holds true, then it would prove that it's driver error on the op's part, but if it doesn't, then there is a possibility that the problem could be mechanical as I tend to belive.
If you are interested reading up on tranny issues, a search of the C5Z archives will give you plenty of material.
My point was that if it take two hands to move the shifter, one cause is a trashed tranny; the other is shifter cradle problem. Neither one is intermittent. The context of the issues in this thread were max acceleration runs, rather than casual driving, at least that's the way I read it.
Ranger
