[Z06] Missed 3rd (strange)?
Old Aug 9, 2007 | 12:06 PM
desant89's Avatar
desant89
Default Missed 3rd (strange)?
I finally tried to wind my 03Z out abit now that I am pretty used to it. I consider myself a pretty good driver, but have only had about a dozen or so passes at the track in the past. I have had much more experience than that tohugh . However, I notice a couple of times now, when shifting really hard to 3rd, I ended up between 3rd, and 5th somewhere. The shifter did go up in there, but nothing grabbing at all as if I had the clutch pedal in. Anyone ever have this happen, I am sure I will become more familiar with it, but should the shifter even go up in there? Thanks!
Example of where I ended up wiht the shifter (x marks the spot)
1 3x5 R
2 4 6
Old Aug 9, 2007 | 12:08 PM
BonestockZ06's Avatar
BonestockZ06
No such place as far as I'm concerned.
Old Aug 9, 2007 | 12:30 PM
Ranger's Avatar
Ranger
Originally Posted by desant89
...I notice a couple of times now, when shifting really hard to 3rd, I ended up between 3rd, and 5th somewhere. The shifter did go up in there, but nothing grabbing at all as if I had the clutch pedal in. Anyone ever have this happen....
The 2-3 missed-shift is almost always caused by a hand position issue. That's often accentuated by the excitement of making a max acceleration run, whether on the street or track.
To solve this problem: How to Improve Your Shifting
Ranger
Old Aug 9, 2007 | 05:22 PM
desant89's Avatar
desant89
Should the shifter of have been abl ot be pushed up in that area anywhere, and the car act like it is in neutral though? It seemed like it went into third, but would not move. But when taking it out of gear, and putting it back in 3rd, it seemed to be off to the right just a little bit. I understand the excitement factor, and am not going to say it is the first time I have ever missed a gear, but I have never seen the shifter seem to go into a gear (or at least near it) fully forward on the shifter, and then be able to just rev the engine as if I were in neutral.
Old Aug 9, 2007 | 05:32 PM
Z06David's Avatar
Z06David
Your clutch may have stuck when you put it in third, its' happened to me before.
Old Aug 9, 2007 | 05:38 PM
Ranger's Avatar
Ranger
^^^ You definitely missed the 3d gear shift gate by causing the shifter to move laterally, wide to the right.
Had you entered the shift gate correctly, when you executed clutch-out, the shifter would have either
(1) remained in gear or
(2) violently kicked the shifter back toward you if it were not fully seated.
Neither (1) nor (2) occurred, based on your description.
Therefore, the explanation is you did not enter 3d, but missed it wide to the right.
Again, this is a very common problem. Keeping your thumb off the shifter and pushing the shifter with the heal of the hand straight toward the radio is the prescription for accurate 2-3 shifts. Drills to embed that position and motion will permanently enable fast, accurate shifts to 3d and every other gear too.
Ranger
Old Aug 9, 2007 | 05:44 PM
desant89's Avatar
desant89
Thanks for all of the advice guys. I will get to practicing some more Ranger. I am pretty sure I do have my thumb involved in those shifts....
Ranger's Avatar
Ranger
That's termed a "shift refusal." It occurs when the clutch fluid boils due to excessive heat from launch and/or high-rpm shifts and the clutch disc fails to release on clutch-in. That event is usually accompanied by gear noise, because it's essentially a clutch-less shift without the requisite rev-matching. No chance of success and some irritating sounds to remind you.
Solution entails Taking Care of Your Clutch.
Ranger
Old Aug 9, 2007 | 05:53 PM
bumble-z's Avatar
bumble-z
I had the same problem when I bought my 03 Z new. Did my hole shot, hit second and no problem, then missed third almost felt like the shifter hit a wall. After doing this for about the third time in short period of time I was feeling real sick. Did some research and found out I was'nt the only one having this problem. Bought a new Hurst shifter installed it and hav'nt had a problem since. The difference between the stock shifter and the Hurst are incredible. The stock shifter has this big rubber isolator at the end of the shaft which I think causes the problem. The best thing about changing the shifter out is you do every thing from in side the cabin. Thought I'd share this information with you. HAPPY SHIFTING!!!!
Old Aug 9, 2007 | 06:53 PM
Higgs Boson's Avatar
Higgs Boson
I had an 01 Z28 that felt like it was getting jammed between 3rd and 5th when powershifting. It took two hands to pull it out of wherever it was. Installed a Pro50 shifter and cured it. The stock shifter just sucks is all. Upgrade.
Old Aug 9, 2007 | 07:20 PM
Ranger's Avatar
Ranger
578 passes in three Z06s, all with the stock shifters and zero tranny issues. How to Improve Your Shifting
Ranger
Old Aug 9, 2007 | 07:21 PM
TEXHAWK0's Avatar
TEXHAWK0
A Hurst shifter is spring loaded so it is almost impossible to miss the 2nd to 3rd shift.
You have to be deliberate in going from 1st to 2nd, but it automatically goes from 2nd to 3rd.
Old Aug 9, 2007 | 07:58 PM
Higgs Boson
Ranger
Great job. Can you please post the link just once more?
Old Aug 10, 2007 | 08:40 AM
Ranger's Avatar
Ranger
Performance-focused driving is like any sport. No one gets good without proper technique and practice to set muscle memory.
Many actions in sports become harder when the speed of execution is increased. Shifting gears is a good example of that. Most owners have no trouble shifting gears until they first begin to shoot for max acceleration. Fast action can yield errors.
The simple, direct approach is to adopt the hand position the prevents pronation of the wrist during fast movements. It is the pronation that guides the shifter wide of the gear gates.
So, some practice with a neutral hand position that blocks pronation will prevent the missed shifts.
To use a another sports analogy, a golf pro will look at your grip and swing mechanics for adjustments, not immediately prescribe a new set of clubs.
Ranger
Old Aug 10, 2007 | 09:40 AM
Higgs Boson
Bad example, IMO. Golf is much more intricate and complex than shifting a car. Besides, what would you consider a stock set of golf clubs? What would you consider the "right" way to swing a club when every player has their own style? What about different clubs for different situations and different swings for different situations? Etc. What happens when people are shifting properly and just have faulty equipment? What happens when the clutch sticks with spotless fluid? Is there really no room for reality? Sometimes equipment other than mass produced lowest bidder parts are useful. Please make room for that idea. Just a little room. Then let us have fun with our hobby instead of breaking everything down to pronation and supination of our carpal row.... Just a thought. Seriously, no offense. All your helpful links are appreciated. But there's more out there.
Old Aug 10, 2007 | 09:51 AM
Ranger's Avatar
Ranger
The solution to every problem is not changing parts. Unfortunately, that's the prescription advanced by some, causing owners to spend $$ to fix issues that are easily remedied by self-help.
Ranger
Old Aug 10, 2007 | 10:56 AM
Higgs Boson
Ranger
I agree but herbal/natural remedies don't always work either. I'll meet you in the middle. They both help but neither is definitive for everyone. Always better to try free first.
To Missed 3rd (strange)?
Old Aug 10, 2007 | 11:05 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Here we go again.
Old Aug 10, 2007 | 11:42 AM
BonestockZ06
No disrespect to Ranger, but I can See Higgs Boson's Point and it makes good sense to me. Sometimes there's just more to it...
Old Aug 10, 2007 | 01:02 PM
Ranger's Avatar
Ranger
I've been very fortunate in my sports life to have good coaches that specialize in solid fundamentals. They often found I needed to make small adjustment to my technique.
Instead of fighting those suggestions, I tried them and practiced using the adjusted movements. And, not surprisingly, my level of performance improved, sometimes dramatically, as a consequence.
In performance driving, some owners fiercely resist any change in their driving technique. Instead they quickly gravitate to buying replacement hardware. Easy to rationalize that an issue must be the fault of the car or a part rather than driver technique.
But, of course, changing out parts doesn't always bring the anticipated result. And owners who ignore the central role of technique usually don't manage to improve very much.
Ranger
P.S. I'm a self-taught, decent tennis player. A tennis-pro watched me rallying with my hitting partner. The pro gave me an unsolicited tip to adjust my grip slightly for better top-spin on my backhand. He was right. And with 20-minutes of practice to embed the adjustment, I solved a shot problem that had diminished my game for two years.
Tennis is a complicated sport. But small adjustments to hand position can solve some issues. Just like they can in shifting gears.
