Weird Trans leak
Old Aug 9, 2007 | 08:25 PM
richieice's Avatar
richieice
Default Weird Trans leak
On Sunday of last week I did 2 runs at 0-105. On Thursday of the following week I go under it and noticed that the passenger side of the exhaust was pretty stained with Trans fluid. Not a drop on the floor though. Does this sound like a one time thing or should I take it in to be looked at?
Old Aug 9, 2007 | 09:37 PM
You need to make sure that its not your rear differential seal also. Either way, I'd want to know if it was leaking or just tranny fluid coming out the vent.
Old Aug 17, 2007 | 01:24 AM
jirasvet's Avatar
jirasvet
I know i had mine fixed under warranty and that the side plate cover on the trans was leaking. And also had dif cover and seals replaced
Old Aug 17, 2007 | 11:40 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Check the Rear End and also it might be from the tranny overflow
Old Aug 17, 2007 | 12:41 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
That is one thing possible and the rear seal too
To Weird Trans leak
