HVAC probs
Old Aug 10, 2007 | 05:48 PM
thomdickinson's Avatar
thomdickinson
Default HVAC probs
I'd like to know if anyone has experienced similar problems as I am about to describe with my C5. Hopefully you can give me a solution or at least give me enough knowledge that I can talk from an informed point of view when I go to the dealer with this one. I get no HVAC codes. Display always display what I select, but with no results.
Heater and A/C ducts all seem to disperse a little bit of air.. all of them.. all at once, regardless of the settings. For example, I can choose "floor" but it makes no difference.. all vents (floor, dash and defrost) all disperse a little bit of air. Makes no difference what mode I am in.. be it ventialtion, heat or A/C. Seems like the deflector doors in the vents are not functioning or ???
Any experiences/solutions out their?
THanks..
Old Aug 10, 2007 | 06:15 PM
Keldane's Avatar
Keldane
Try putting on c5 tech thread
Old Aug 10, 2007 | 07:18 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Default did battery leak?
not sure, but thought I read that if the battery leaked, it leaked on equipment underneath that could cause various problems, possibly like yours.
Old Aug 10, 2007 | 09:09 PM
thomdickinson
New abttery and no leaks..... thanks for the suggestion though....
To HVAC probs
