Steering Column Won't Unlock
Old Aug 10, 2007 | 09:23 PM
BlackWidow01's Avatar
BlackWidow01
Default Steering Column Won't Unlock
Hi all,
I have a 2001 6speed. I encountered a PULL KEY WAIT 10 SEC message and installed a bypass module from Corvettes of Houston and then use the 12 volt adapter to unlock the column. Unfortunately it still won't unlock but the message does not display anymore. I must of tried numerous suggestions without success. Now I dread the idea of having to tow it to a dealer. Which mean tow damage and dealing with the dealer. If I understand correctly....It would be covered through GM Recall? My only other option is to manually disengage the locking mechanism manually which involves deactivating the SIR among other things. Im hoping someone here has an idea what other options I have?
Old Aug 10, 2007 | 09:26 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
disconnect the battery wait a few minutes..reconnect and try again...
Old Aug 10, 2007 | 09:30 PM
johninar's Avatar
johninar
After reading many threads, I'm a firm believer in shaking the steering wheel back and forth. Many members have had success with it.
good luck.
Old Aug 10, 2007 | 11:33 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
One thing I see in your post is that you installed a CLB in a car with the column LOCKED. The CLB doesn't unlock the column. You have to unlock the column (per the instructions) THEN install the CLB to avert future bad reports to the BCM. You did well to buy the CLB (I see you have the COH version) but need to read the instructions and sticky on Column Lock at the top of C5 Tech and you will be fine. I would suggest you NOT take your car to any dealer to try and correct this.
Old Aug 11, 2007 | 01:45 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Used to work for me before I installed the CLB from COH. Good luck!
Old Aug 11, 2007 | 01:54 AM
pewter99's Avatar
pewter99
well I think he meant he installed the module then used the adaptor to unlock it but it wasn't clear which is why I suggested the battery disconnect and then try again....but yeah you are right...you have to unlock it first...
hopefully one of these suggestions works..
Old Aug 11, 2007 | 02:52 AM
DeeGee's Avatar
DeeGee
Great advice
Old Aug 12, 2007 | 10:59 PM
BlackWidow01
Default Thanks All
I want to thank everyone for thier suggestions. Unfortunately it looks like I will be removing the lock plate and installing a CLB afterwards. Another project for the weekend.
To Steering Column Won't Unlock
