Made some tail light seals
Old Aug 11, 2007 | 09:41 AM
mcgilles's Avatar
mcgilles
Default Made some tail light seals
I decided to try to put some gaskets of some kind around my taillights to prevent the dripping water making the rear all dirty. I went out and got some rubberized weather seal, the smallest I could find so it would fit. I measured it and cut and installed it around the outside of the taillight lens. when installing I found out that even the smallest one available was too thick, I couldn't get the lenses back on the car, the gaskets were too thick. so at first I figured oh well, it was worth a try, I'm not out much. Then I went for another take on the problem. I removed the strip from the taillight lens and moved it to the bumper around the socket where the taillight lens is mounted. here's what it ended up looking like:
since the gasket fits behind the lens it doesn't interfere with it fitting at all. as an extra bonus it pushes the tailights out slightly. its not as much as the flush mount kits (which I don't like the looks of anyway) but the lenses are moved outwards a small amount, maybe 5mm or so. they are still inset into the bumper just how I like it but having them slightly farther out looks really good. I'm pretty impressed! You can't see the gasket at all when the lights are installed, its behind the lens rather than around it.
what I got was called Marine & Automotive weather seal, 8mm thick, 29mm wide, 5.2m long. they call it the "Black D Profile" not too expensive, I found it on the shelf at Lowes.
Just thought I would share!
Old Aug 11, 2007 | 09:44 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
That looks great! I am going to have to look into that!
Old Aug 11, 2007 | 10:01 AM
rws.1's Avatar
rws.1
I found some at Lowes. It was available in Black ,Gray,White and Brown since I have a QS Vette, I opted for the Gray
Here is what I bought Frost King extreme weather seal 3/8" by 1/4" thick 17 ft was about $6
Here's it installed
Old Aug 11, 2007 | 11:34 AM
b98's Avatar
b98
thanks I think I will try it.
Old Aug 11, 2007 | 11:40 AM
Corvette Don's Avatar
Corvette Don
Awsome I will try that too
Old Aug 11, 2007 | 12:17 PM
Brad@RevXtremeAutoSports's Avatar
Old Aug 12, 2007 | 01:12 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Very nice and an inexpensive mod
Old Aug 12, 2007 | 01:14 PM
fastvett's Avatar
fastvett
Old Aug 12, 2007 | 05:01 PM
vette1111's Avatar
vette1111
I have always wondered if a o-ring wedged in there wouldn't work? Anybody try that?
Old Aug 12, 2007 | 05:39 PM
slverc5's Avatar
slverc5
Good, just finished cleaning my car yesterday. I will be off to Lowe's in the am to get me some ( seals of course)
Old Aug 12, 2007 | 05:44 PM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Looks good!
Old Aug 12, 2007 | 05:50 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Old Aug 12, 2007 | 05:56 PM
C5 RACNG's Avatar
C5 RACNG
this is what I used, worked out perfect
available at Loews
Old Aug 12, 2007 | 07:18 PM
jrprich's Avatar
jrprich
[QUOTE=rws.1;1561454140]I found some at Lowes. It was available in Black ,Gray,White and Brown since I have a QS Vette, I opted for the Gray
FYI,
This same D weatherstrip in Black makes a nice front hood seal.
Just run it along the top edge of the front clip edge.
When the hood closes, it makes a good seal for water and dirt.
Old Aug 12, 2007 | 07:47 PM
csexton's Avatar
csexton
Looks good
Chuck
Old Nov 4, 2007 | 02:32 AM
hawaiiC5's Avatar
hawaiiC5
St. Jude Donor '09
available at Loews
i bought some today and they fit perfectly
Old Nov 4, 2007 | 06:33 AM
Junkman2008's Avatar
Junkman2008
Hey MC, doesn't the water still get under the tail lights after you did this? I don't understand how you're able to keep the water out when doing it the way you did.
To Made some tail light seals
Old Nov 4, 2007 | 07:27 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
So who said Corvette mods have to be expensive!
Great info, I'll pick some up the next time I'm at Lowes.
Old Nov 4, 2007 | 07:33 AM
vettes4fun's Avatar
vettes4fun
Good thanking
Old Nov 4, 2007 | 08:02 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
You guys should be ashamed of yourselves for not paying your Corvette taxes, I hope you don't get audited!
