Made some tail light seals
Old Nov 10, 2007 | 07:31 AM
  #41
Junkman2008's Avatar
Junkman2008
Originally Posted by rickko
I like your idea and the hole drilling idea because I got gigged for the exposed seals in a car show (stock class). So, I removed them.
There is always a better mouse trap!
..rickko..
How can they gig you for that? They're supposed to show!
Originally Posted by TheRadioFlyer
Went to home depot looking for them, HD only has brown and white. I'll assume lowes does normal colors then.
Good luck. I was only able to find them in gray and white at Lowes. By the way, if you buy the "tear drop" style rubber, they'll fit easily into the tail light housing.
Old Feb 9, 2008 | 10:28 PM
  #42
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
[QUOTE=jrprich;1561469699]
Originally Posted by rws.1
I found some at Lowes. It was available in Black ,Gray,White and Brown since I have a QS Vette, I opted for the Gray
Here is what I bought Frost King extreme weather seal 3/8" by 1/4" thick 17 ft was about $6
FYI,
This same D weatherstrip in Black makes a nice front hood seal.
Just run it along the top edge of the front clip edge.
When the hood closes, it makes a good seal for water and dirt.
Cool idea. I may have to pick some up just to give it a try.
Old Feb 10, 2008 | 02:01 AM
  #43
ZEX-Z's Avatar
ZEX-Z
Why do you put seals behind the rear tailights?
Old Feb 10, 2008 | 02:06 AM
  #44
DeeGee's Avatar
DeeGee
Have to say i did mine the same way as slverc5. The seal around the light unit closes the gap and stops the water collecting at the base.
Old Feb 10, 2008 | 09:37 AM
  #45
mcgilles's Avatar
mcgilles
because GM didn't :-)
water can flow past the tail lights and collect there. when you wash your car you will notice that after drying for hours water always keeps reappearing behind the lights making you continuously redry that area. since there's no way to clean behind there easily, the water that keeps running back out is always dirty and keeps the back of your car dirty. It won't really hurt anything, but the seals fix the problem.
Old Feb 10, 2008 | 10:48 AM
  #46
MagneticRed1977's Avatar
MagneticRed1977
Default Great Mod
Hats off- very creative!
Old Feb 10, 2008 | 12:13 PM
  #47
LEANDRO's Avatar
LEANDRO
Old Feb 21, 2008 | 12:29 PM
  #48
zwaldo's Avatar
zwaldo
Default curious
if anyone used the same to seal their hood, or if they used a diffrent size. and if there where any pics?
Old Apr 2, 2008 | 01:37 PM
  #49
VETFEVER's Avatar
VETFEVER
Forums guys (and gals) are so clever
Old Apr 2, 2008 | 01:49 PM
  #50
dndrsn's Avatar
dndrsn
Originally Posted by Junkman2008
Hey MC, doesn't the water still get under the tail lights after you did this? I don't understand how you're able to keep the water out when doing it the way you did.
Old Apr 2, 2008 | 01:53 PM
  #51
bucwheat's Avatar
bucwheat
Here's it installed
How long a strip do you cut per light?:o
Old Apr 2, 2008 | 01:54 PM
  #52
VETFEVER's Avatar
VETFEVER
Default Seals
I was thinking that if you did BOTH what MC and slverc5 did that you get the benefit of the lens moving up a 1/4" or so (if you like that look - which I do) and by the lens moving up, the seal in "the crevice" will fit a little better as the fit would not be so tight (careful now guys!). Rather than silcone I would use Armour All - makes things slippery and protects the rubber at the same time (more careful, my bad....)
Old Apr 2, 2008 | 03:21 PM
  #53
Junkman2008
Love your avatar Jack. Someone loves you!
Old Apr 2, 2008 | 03:48 PM
  #54
VETFEVER's Avatar
VETFEVER
Thanks...that would be my (now) 6-year old....
Old Apr 3, 2008 | 12:12 PM
  #55
VetteFTW's Avatar
VetteFTW
I went to lowes and I couldn't find this stuff. Where do they keep it? I was looking at the weatherstripping area and they had no frost king products at all.
Old Apr 3, 2008 | 12:37 PM
  #56
tlc0706's Avatar
tlc0706
Found the "sound deader" products on left side as you enter, behind lawn mowers and with the vent material. The tape you are looking for however, is to the right about 3/4 way down the store (toward lumber).
It is located with home weatherstripping and insulation. Good luck
Tom
Addition: It's on aisle 14 or close
Old Apr 3, 2008 | 04:23 PM
  #57
VetteFTW's Avatar
VetteFTW
I found some at Tru-Valu hardware store. But all they had was brown. I got it anyway since the light will cover it. Does anyone think I can paint a strip of it black to use for a "performance hood seal"?
If so, what sort of paint should i use that won't run if wet? Enamel?
To Made some tail light seals
Old Apr 3, 2008 | 04:46 PM
  #58
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
I'll have to try this.
Old Apr 4, 2008 | 01:48 AM
  #59
itzza427's Avatar
itzza427
Great mind must run in the same rut...(I've only had my C5 a couple of months)while I was driving the other day the thought crossed my mind about drilling a hole so the water can drain,,BAM here it is in a post.Thanks for confirming the concept.There's nothing under there but the bumper structure and the mufflers that I can think of.
Old Apr 4, 2008 | 10:21 AM
  #60
c5streak's Avatar
c5streak
After my original post, other than not wanting to drill a hole in their cars, I still don't see why everyone wants to spend money for seals that aren't needed. Five minutes with a cordless drill and your done, for free! Just my.02.
