Brake Calipers
Here is how I do them.....
http://www.iammoon.com/c5tech/caliper_painting.htm
best regards -
mqqn
best regards -
mqqn
I was going to post mine but after seeing the time and effort that went into that, I'll just move along.
I did use the chapstick on the "Corvette" letters and I thought it worked well for me.
Best of luck.
It's not clear to me if I can do MORE than one at a time -- maybe 1 front and 1 rear? All 4?
Or, does anyone know of a cap to put over the line while the caliper's removed to keep air from getting in?
Any recommendations or thoughts on this at all would be appreciated.
Does ABS screw with any of this?
If I had it to do all over again I would remove them and have them powder coated. The quality can't be beat!
If you did not get them powder coated then use a spray can of paint. I used that on my brackets and they turned out nice.
I used a razor blade to shave the paint off the corvette letters. Very easy and looks great. If you wanted to paint them using a small paint brush would be easy but the silver letters look great even without paint.
Good luck...they really do look better painted just remember the prep work is what takes the longest and is the most important.
Thanks! The more the merrier, though - post up your how too!
best regards -
mqqn
Really I just had some pictures...
I had installed some GM cross-drilled and slotted rotors on the car shortly after I bought the car. Within a short amount of time, the rotors rusted up pretty bad and the whole area left a lot to be desired.
I removed the calipers, leaving the hoses attached, and supported them on top of the axle. I covered the wheel well with yard-sized trash bags and covered the car with those cheap plastic painters drop cloths.
I used "VHT" spray paint from Autozone.
I used some clear on the fronts and it seemed to work out pretty good too.
I cleaned the calipers, brackets and rotors with a wire brush and brake parts cleaner.
On the front calipers I used chapstick accross the "Corvette" letters to aid in paint removal from the letters alone.
I did not tape off the rotor as I wanted to make sure it got covered well.
I also gave the "fins" a light coat.
After everything was back together, the overspray on the rotor face was gone by the end of the driveway. It did shutter initially, but that was that.
Its been about two years now and everything still looks good.
I need to take the wheels off to give everything a good cleaning but thats about it.
Rears before.
Rear after painting, before driving.
Fronts being sprayed.
Done, and after a quick drive to clear the rotor.
as they are not zinc dipped and will rust the first time you drive in rain
or wash the car. (at least they are not made in China) I painted mine and put on the chrome rotor hats.
I went and shelled out the bucks to get the Z06 powder coated calipers.
The calipers are not heavy and the weight is not putting any undue pressure on the lines in this case.
On some cars, yes, the calipers can be heavy and the lines held at such an angle as to potentially harm the lines, but not in this case at all.
Not a problem with stock C5 brakes if you do it just like I show.
Can you show me any evidence that this is damaging to the brake lines?
best regards -
mqqn
best regards -
mqqn
I know that used to always be the rule - but the brake calipers are much lighter than they used to be.
I have to let them hang to get them low enough to paint without having to mask off the whole car etc.
Incidentally, when many techs work on C5 (and I assume other cars) brakes, they clamp off the brake line (!!) to prevent having to bleed the brakes and or to prevent fluid loss.
So - I respect your caution, but I have done several C5's like this with absolutely no problem - and one of the cars was track-run several times after we did the work.
best regards -
mqqn
