shift knob dilemma!
Old Aug 15, 2007 | 10:36 AM
Maites's Avatar
Maites
Default shift **** dilemma!
Ok so heres the deal...I had my stock c5 shifter modified to become a c6 z06 shifter. It was cut shorter and bent exactly the same as a c6 shifter. My question is, I want a c6 **** but I'm not sure if it will fit. I was told by the member who modified my shifter that the c6 **** will twist right on and I will be good to go. However, I was about to buy a c6 **** from a diff member and he told me it is not threaded and there is a screw to hold it in place....does anyone know what I need to do? I know they make the c6 **** special to fit the c5 shifter, but since mine has been modified im not sure which to buy...
Old Aug 15, 2007 | 11:20 AM
Bills03Coupe's Avatar
Bills03Coupe
The C6 **** will not fit the C5 shifter without first being modified. It needs to be threaded to work. There is a seller on Ebay, GS Creations,that sells a **** that is modified to fit your shifter. Check out item # 150150939843.
Old Aug 15, 2007 | 11:29 AM
RUNNINGMAN 1's Avatar
RUNNINGMAN 1
You will need to buy the shifter on e-bay there is a seller who sells a modified c6 shift **** to fit the c5 with threads instead of screwed.
Old Aug 15, 2007 | 12:14 PM
Ron71's Avatar
Ron71
The stock C6 **** does not contain threads but others have drilled and tapped a hole in the stock shifter rod so that the factory C6 shifter **** cn be used.
Old Aug 15, 2007 | 12:51 PM
Maites's Avatar
Maites
gotcha.. thanks guys.. I knew about the ones on ebay but am tryin to get one at a cheaper price...thanks for the info.. may have to go that route..
Old Aug 16, 2007 | 11:13 AM
Maites's Avatar
Maites
ordered the gs creations ****... $95... steep for a shift **** if you ask me....oh well
Old Sep 11, 2007 | 02:37 PM
NeoZ06's Avatar
NeoZ06
i installed it on my 2004 Z06, man i should've done this a long time ago...!!!
100x better look and feel than the stock one...
Old Sep 11, 2007 | 02:57 PM
Maites's Avatar
Maites
agreed!!!! I love it
To shift knob dilemma!
