Ceramic pad dust!
Old Aug 15, 2007 | 10:48 AM
bilx013's Avatar
bilx013
St. Jude Donor '12
Default Ceramic pad dust!
Just had new cross/slotted rotors and GM ceramic pads put on and the brake dust on my front C5 Z chromes is horrible! Thinking of changing the fronts to semimetallic. Any one else experiancing this and what was your resolution?
Old Aug 15, 2007 | 11:07 AM
Vega$Vette's Avatar
Vega$Vette
The drilled and slotted will cause more dust initially (light gray color). You should be OK after a few miles.
Switching to semi metallic will give you more dust and it will be almost black.
Old Aug 15, 2007 | 11:14 AM
jrose7004's Avatar
jrose7004
I think that it will settle down after a few miles.
bilx013's Avatar
bilx013
St. Jude Donor '12
I definitely don't want MORE dust.....
Old Aug 15, 2007 | 11:17 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I thought the whole point of using ceramic is less dust. They're generally noisier and less effective. Wouldn't switching back would just cause more dust?
Old Aug 15, 2007 | 11:18 AM
csexton's Avatar
csexton
Let them bed in for a while and see what happens
Chuck
Old Aug 15, 2007 | 11:30 AM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
Mine were the same way for awhile.
Old Aug 15, 2007 | 11:36 AM
bilx013's Avatar
bilx013
St. Jude Donor '12
Thanks guys...I won't change them just yet.
Old Aug 15, 2007 | 03:49 PM
vetdude's Avatar
vetdude
The "problem" is with the slots in the rotor and not the pads. These are really meant for track use since the slots shave off the top surface of the pads to eliminate glazing in high heat applications. You would have been better off going with just the drilled rotors if street use only - no dust.
Old Aug 15, 2007 | 04:07 PM
rws.1's Avatar
rws.1
No appreciable dust on my D+S rotors with AC/Delco Durastop ceramic pads.
So I am puzzled by your comments...
Now switch to my Hawk HP+ pads and within 50 miles of driving the wheels are BLACK !
Old Aug 15, 2007 | 04:25 PM
FKING1's Avatar
FKING1
Raybestos Q Ceramic/Meallic here.Less dust than stock, but, still more than I like. Nothing on the rims, only on side gills and rear facia.
Old Aug 15, 2007 | 04:28 PM
Old Rotor Head's Avatar
Old Rotor Head
I've got the same set-up and the mega dust went away after 100 miles or so.
Old Aug 15, 2007 | 04:44 PM
Luv2Run's Avatar
Luv2Run
St. Jude Donor '13
Same as others have posted...dust lasted for a few hundred miles (i assume it varies with how aggressive you apply the brakes)
Virtually no dust with the ceramics after 14k miles of use!
I'd give it some time.
Don
Old Aug 15, 2007 | 07:27 PM
dw99vette's Avatar
dw99vette
From: 15 miles south from the Raisin Capitol of the World Caifornia
Old Aug 15, 2007 | 07:35 PM
Vega$Vette's Avatar
Vega$Vette
But the Slots look...
Old Aug 15, 2007 | 07:36 PM
jon c's Avatar
jon c
Mine did!!!!!
krm_wi_C5's Avatar
krm_wi_C5
I had the Hawk HPS pads installed recently, very little dust.
To Ceramic pad dust!
Old Aug 15, 2007 | 08:44 PM
T VETTE's Avatar
T VETTE
AFTER THEY SETTLE IN IT'S ALL GOOD, YOU WILL NEVER GO BACK TO METALLIC. DON'T THOSE BMW AND MERCEDES WHEELS LOOK LIKE *HIT
Old Aug 15, 2007 | 08:54 PM
Jet-Jock's Avatar
Jet-Jock
They should settle down. Durastop Cermaics are very good pads, used them on the '93.
Did you bed the pads after installation?
Let me clarify this: Did you or whomever installed them bed the pads by doing 20 consecutive stops from 30 MPH. Take it up to 30 do a hard firm stop, and repeat 20 times. By about 18 you will begin to smell the pads and experience a slight fading if you used a good pad. Park it and let them cool down some and your good to go. The pads are mated to the rotors, bedding the shoes as it's known.
You'll know if you used a poor pad, getting from 18-20 a poor pad will fade fast and be nearly gone.
Old Aug 15, 2007 | 11:28 PM
My Hawk HPS pads had a lot of dust initially, but after driving it for a while, it has shown a significant reduction.
