Vette Wont Start!!?? Please help
Old Aug 15, 2007 | 01:31 PM
hayman's Avatar
hayman
Default Vette Wont Start!!?? Please help
Came home for lunch (3 mile drive) today. Put the key in the ignition, as I do since I purchased it, buckle up as the seat and steering wheel resume my settings and turn the key and nothing. Seems all the electrical is working fine, seat, steering and radio but no starter.
The only thing I've done to the car in a little over a month is install the CLB. Could this be causing the problem?
No code or warnings.
Bill
1999 vert
Old Aug 15, 2007 | 01:45 PM
DSM TJ's Avatar
DSM TJ
does everything work on the on position and then when you turn it to start everything goes dead? if so, you may have damaged the chip on your key or got it dirty. if this hasn't happened, it's something else.
Old Aug 15, 2007 | 02:10 PM
Mr. Couture's Avatar
Mr. Couture
maybe you have some old spark plugs or just need a jump start..just my $.02
good luck
Old Aug 15, 2007 | 02:34 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I doubt its the CLB although I guess it could have come loose.
Better guess is bad battery, Bad Clutch position switch, or bad starter.
If you can jump start it you can rule out the starter and the clutch switch and the CLB.
Good Luck
Old Aug 15, 2007 | 03:20 PM
VinnyT's Avatar
VinnyT
Clean the key pellet off with a pencil eraser.
Old Aug 15, 2007 | 04:01 PM
hayman's Avatar
hayman
Aww, WTF? I get home from work, get in, turn the key and it starts. Shut it off, pull the key. Put the key back in and it starts right up.
Now I'm worried to drive it anywhere. I bought it for my daily driver.
Thanks for the suggestions. If you can think of anything else….
Bill
Old Aug 15, 2007 | 04:13 PM
Bruceatlam's Avatar
Bruceatlam
Auto or manual --- I know that my leg gets lazy from time to time and I don't push the clutch in far enough. Same symptoms.
Check you battery ----------
Old Aug 15, 2007 | 04:29 PM
hayman's Avatar
hayman
Manual and I like my seat close enough that the clutch bottoms out. Stopped at my storage to get the jumper cables just in case.
Bill
Old Aug 15, 2007 | 04:40 PM
SinghZvette's Avatar
SinghZvette
Like others said, most prolly was dirt on the chip on your key .. happens to me when I stuff lunch in my pocket with the car keys
Old Aug 15, 2007 | 05:02 PM
PostShawn's Avatar
PostShawn
This happend to me about a week ago. I never did find out what it was and even posted about it here. I went out for lunch from work, not to home either. And I get back in the car to go back to work and no start. Same as you. I kept trying and nothing. Looked at all the hoses and connections I can see and nothing wrong. I waited a couple minutes and decided to give it a shot before calling my roommate and it started right up. I just got the car a few weeks ago and nothing before or after like that happend. I still don't know why it happend so I am interested if you find anything out.
Best of luck on yours.
Old Aug 15, 2007 | 05:05 PM
LoneStarFRC's Avatar
LoneStarFRC
Double check your battery connections, etc. How about codes?
BTW, check the connector on your CPP (Clutch Pedal Position)switch under the dash too. Just get under there and you'll see it. It's the one that the clutch pedal contacts when you push the pedal all the way down.
Old Aug 15, 2007 | 06:26 PM
stormrider's Avatar
stormrider
I went through your exact starting nightmare last year. Bill Curle, our resident electric guru, told me it was the starter. I replaced the starter and almost a year later she still starts every time.
Old Aug 15, 2007 | 07:10 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
Get a nice new gel cell.
Old Aug 15, 2007 | 07:17 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Check out the ground connection below the battery.
To Vette Wont Start!!?? Please help
