so if i have a M6 with 390s my top speed is around 167? in 5th gear?
Yeah - Depending on your tire size. I have 285/40/18s which are a little taller... but the stock 275/40/18 is a little shorter - and a stock Z06 tire is even shorter...
And at ~165 when you run out of 5th you can shift into 6th and try... if you've added any power to your car, it may still pull into the 170s...
