c5 will only jumpstart
Old Aug 16, 2007 | 10:49 AM
bhard's Avatar
bhard
Default c5 will only jumpstart
hey, my 98 c5 has 108500k and i had it sit for about 3.5 weeks. i get in it yesterday cranks up fine. drove it 2 miles got gas and wont start. popped the clutch with no problem thought it was because it was grumpy that it has not been out. ran it pretty good after that, stopped again later and the same thing happens. all electronics work turn the key and nothing happens, just silence.
what gives?!?!!??!
thank for your help
Old Aug 16, 2007 | 10:57 AM
VinceC5's Avatar
VinceC5
what gives?!?!!??!
thank for your help
if it's not a lose connection at the battery, then it's the battery. Go ahead and have it charged at your local parts place or replace if it won't hold a charge.
Old Aug 16, 2007 | 11:02 AM
DeeGee's Avatar
DeeGee
If its an original AC Delco battery you're already on borrowed time. Change it out before it leaks.
Old Aug 16, 2007 | 11:03 AM
travelingypsye's Avatar
travelingypsye
I have to agree.........
Old Aug 16, 2007 | 11:08 AM
csexton's Avatar
csexton
Best to use a battery tender for those extended times you don't drive the vette
Chuck
Old Aug 16, 2007 | 11:47 AM
bhard's Avatar
bhard
thanks, do you have any suggestions for a good replacement battery?
Old Aug 16, 2007 | 11:59 AM
champ53's Avatar
champ53
Oh-oh! Sit down & buckle up! It gonna be a long ride!
Old Aug 16, 2007 | 12:02 PM
02MillenniumVette's Avatar
02MillenniumVette
Old Aug 16, 2007 | 01:57 PM
DAN01's Avatar
DAN01
I purchased the Optima Red Top 2 years ago and have had no problems.
To c5 will only jumpstart
