Gas ?
Old Aug 17, 2007 | 06:18 PM
cfee's Avatar
cfee
Default Gas ?
Can you really tell a difference in 89 octane (in the gas pedal) or 92 octane? I have a race with my buddy and he drives a 07 Mustang GT (nice car) with a 5 speed trans. I have a 97 C5 auto. No engine MODs on either car, can I bet him?
Old Aug 17, 2007 | 07:13 PM
chris308's Avatar
chris308
i can't speak for everyone but, my vette does not like cheap or low grade gas at all!!! I always use 93 from mobil w techron additive or just fill up with shell.
Old Aug 17, 2007 | 07:20 PM
R Devil's Avatar
R Devil
Yes
Old Aug 17, 2007 | 07:28 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Not only can you tell but if you keep putting that cheap crap in your tank, you'll get to experience the fun of replacing your gas gauge. How cool would that be?
Old Aug 17, 2007 | 07:32 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Doesnt the book call for 91?
Old Aug 17, 2007 | 07:41 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
You can use the cheap stuff and the computer will compensate but you won't make all the power it's capable of. Whether you can actually feel the difference, I doubt it. GM recommends 91 octane for an unmodified LS1.
Old Aug 17, 2007 | 08:01 PM
LT1driver's Avatar
LT1driver
I have used mid grade 89 octane on a stickly road trip, but only used shell, chevron or similar. it works for me on long 4500 mile trips ... to each his own however.
Old Aug 18, 2007 | 12:12 AM
rws.1's Avatar
rws.1
The lower the octane rating, the more likely the presence of knock at WOT.
When the PCM senses knock it retards timing causing a signficant loss in HP
Old Aug 18, 2007 | 12:36 AM
Dominic Toretto's Avatar
Dominic Toretto
This was answered in the other thread. Different octane yields different results. That's why the stations offer different octanes, and they cost differently.
As stated before, buy premium for your Corvette. It's not a damn Civic.
-Alex
Old Aug 18, 2007 | 01:16 AM
JH's Avatar
JH
And your speed contest will occur on a sanctioned drag strip, right?
Always premium for me, but I can only get 91 octane up here in Colorado.
Old Aug 18, 2007 | 01:38 AM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Why use cheap gas? Get the most out of your car and avoid replacing your fuel gauge...use a Top Tier gasoline.
Old Aug 18, 2007 | 03:09 AM
DeeGee's Avatar
DeeGee
The book actually says:
Fuel
Gasoline Octane
Use premium unleaded gasoline with a posted octane of
91 or higher for best performance. You may also use
middle grade or regular unleaded gasoline rated at 87
octane or higher, but your vehicle’s acceleration may be
slightly reduced. If the octane is less than 87, you may
get a heavy knocking noise when you drive. If it is bad
enough, it can damage your engine.
The knock sensor is a reactive device. In other words the damage however minor has occurred when it makes the timing adjustment. Once thats happened as rws1 says, the fuel economy and performance suffer.
E-T who was involved in the design of the C5 had very strong views that with the high compression LS1 you shouldn't use less than 91 octane. Seems sensible to me.
Old Aug 18, 2007 | 06:54 AM
moserbe's Avatar
moserbe
I saw another post on this very subject last night.
Old Aug 18, 2007 | 07:22 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Hmmmmm, lets see,
  • My Z06 cost me a tad over $52,000 when I bought it.
  • The manufacturer calls for the use of premium fuel, 91 octane or above.
  • The difference between regular and premium is $0.30 more per gallon.
  • It costs $5.40 more to fill up from an empty tank.....assuming 18 gallons
Anyone see where I'm going with this?...
Old Aug 18, 2007 | 08:36 AM
csexton's Avatar
csexton
93 here and don't really care to find out how it would run on 87
Chuck
Old Aug 18, 2007 | 08:47 AM
Buckskinner's Avatar
Buckskinner
Default I didn't
after 1/4 million miles I have had no problems with 87 octane gas, for several years I drove 100 to 150 miles a day to work and back, this is my everyday driver and the gas savings over my blazer (12 mpg) or jeep (14 mpg) helped pay for my vette. I still drive 50 miles a day round trip. Occasionally I put a tank or two of shell premium thru it but for the most part I use murphy 87. I haven't had to do anything to the ls1 other than replace the harmonic balancer. it still gets 27 mpg and does not burn oil. some of us like there vettes even though we may not be rich.
Old Aug 18, 2007 | 09:01 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Do yourself a favor and don't buy the cheap lower octane gas. It will cause problems later.
To Gas ?
Old Aug 18, 2007 | 09:09 AM
Buckskinner
Default beg ta differ
No it won't
Old Aug 18, 2007 | 10:23 AM
phoenixfoundmac's Avatar
phoenixfoundmac
Just buy 91 or higher. Sure it will run on something lower, but why tempt fate when it's designed for something higher.
And yes you should be able to beat the mustang especially if you have the 3.15 rear end. Mind you it won't be a walk seeing as he's got a 5 speed.
Old Aug 18, 2007 | 11:39 AM
Halfway's Avatar
Halfway
St. Jude Donor '06
Another example of the C5 being too affordable to kids.....
Is the C5 going to become the new Mustang now? See teenagers driving them around every corner.......
