Callaway Honker
Old Aug 18, 2007 | 11:38 AM
Dealripper's Avatar
Dealripper
Default Callaway Honker
I have a 2000 C-5 with the Callaway Honker Installed. Does anyone know where I can purchase the rubber connector that connects the MAF to the throttle body. Mine has cracked. Is this a factory part. Thanks for any any help on this matter.
Old Aug 18, 2007 | 12:24 PM
If it is an acordian style piece, then you can get it at the dealer. If it is a smooth piece, then contact Callaway for a replacement.
Old Aug 18, 2007 | 01:34 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Like Jack said "if it's an accordion, it's OEM" If it's smooth it's an after market (Callaway doesn't supply one in the kit) My suggestion is to contact Chip (WILLFULONE) at CCA as he just offered a special on his smooth coupler in three color choices. www.customcorvetteaccessories.com
I just bought one less than 5 minutes ago.
Old Aug 18, 2007 | 02:41 PM
rpm462's Avatar
rpm462
Actually the Honker came with it's own piece and it shorter then the stock one because you relocated the MAF. I think you'll have to get with Callaway to see if they can replace it.
Callaway Honker
Stock Air Intake
Hope this helps.
Old Aug 18, 2007 | 05:56 PM
Dealripper's Avatar
Dealripper
Thanks for the info and help. I will email Calllaway to see if I can get a replacement. I need to get it ASAP so that I can go to Carlisle this upcoming weekend.
Earl
Old Aug 21, 2007 | 01:20 AM
Ol'55's Avatar
Ol'55
Callaway Honker
Stock Air Intake
Hope this helps.
Bruce, You're absolutely correct! I don't know what I was thinking. Plus now I have a smooth coupler coming from Chip that I won't need on the Vert.
To Callaway Honker
