oil usage
Old Aug 19, 2007 | 09:29 AM
DFB's Avatar
DFB
Default oil usage
I had to add 1qt. oil to my C5 after 1200 miles?? why??
my car is a 2002 coupe with 10000 mi last oil change sept. 2006, now aug. 2007 with
11200 miles!! thanks for all your help.
Old Aug 19, 2007 | 09:41 AM
Zee916's Avatar
Zee916
There can be a couple of issues that promote this problem. The most likely one is that your rings are going (piston).
Old Aug 19, 2007 | 09:42 AM
rws.1's Avatar
rws.1
GM considers that "normal oil consumption"
What year is your Vette?
There are some '01 that have a ring design that "flutters" allowing some oil blow by... especially if you are running at 4000 rpm and light load
Old Aug 19, 2007 | 09:49 AM
SpeedUp's Avatar
SpeedUp
Just guessing .. is this on a 2001? Your profile isnt filled out.
Old Aug 19, 2007 | 10:48 AM
VinceAD's Avatar
VinceAD
From this Forum's sticky on weights, measurements,etc.,
"Oil woes
Many late 2000 thru 2001 Vette's burn a lot of oil when the engine is kept constantly over 4,000 rpm's. This is caused by ring flutter, which allows extra oil to seep past the oil control rings, but doesn't seem to cause any extra wear to the engine. Chevrolet has rebuilt and replaced engines for owners that complained about excessive oil consumption. Their policy is that while the engine isn't normally operated like that outside of racing, it is the owner's prerogative to drive around in second gear all the time if they want to. It is covered under the warranty.
The PCV system also has a tendency to suck oil back into the intake at high rpm's. It doesn't seem to cause any problems, other than a slight mess inside the intake manifold. The newer style PCV system can be installed, but this requires removing all the components in the top of the engine valley. Usually only racer's bother with the hassle. Several generations of PCV systems have had the problem, and at this time, December 2004, the PCV system still sucks oil into the intake.
The oil-sucking problem will cause carbon buildup in the cylinders. The dealership sells GM Top End Cleaner, and Napa sells SeaFoam. The Top End Cleaner is not available in some smog states like California. Run a tube from the bottle into the hole for the PCV system behind the throttle body on the passenger side. Start the car, then start slowly sucking the solution into the engine. Don’t go too fast or the engine could lockup. As soon as the solution is gone, stop the motor for >4 hours, but preferably 12 hours. Be aware that when the engine is restarted, there will be a LOT of smoke!
The oil-sucking can be prevented by installing a catch can. AMW and Greddy make catch cans, but a homebuilt catch can may be built using a Campbell-Hausfield air tool oil separator from most tool stores, including AutoZone. The AMW and Greddy cans are ~$100, but look great. The CH can is $15-25 for all the parts, and you can see how much oil is in it."
Old Aug 19, 2007 | 10:49 AM
steve8's Avatar
steve8
What year?
Old Aug 19, 2007 | 12:00 PM
DFB's Avatar
DFB
Default oil usage
Originally Posted by steve8
What year?
2002 with 11200 miles
Old Aug 19, 2007 | 12:01 PM
DFB's Avatar
DFB
Default oil usage
no it's a 2002 with 11200 miles
Old Aug 19, 2007 | 12:02 PM
DFB's Avatar
DFB
Default oil usage
What year?
a 2002 with 11200 miles.
To oil usage
