Sometimes Instrument Panel Lights do not work.
Old Aug 19, 2007 | 12:00 PM
luis miguel alonso's Avatar
luis miguel alonso
Default Sometimes Instrument Panel Lights do not work.
I have a 1999 C5 with LG headers and aftermatket stereo (HU Alpine IVA-W202R + 2 Alpine amplifiers)).
When I open the door the instrument lights switch always on, but sometimes when switching the headlights on , the instrument lights do not work. The headlight pops-up and ligths always.
Any advice? Do I need to buy a new headlight switch?
Old Aug 19, 2007 | 04:06 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
During the day-time, the instrument panel indicators are controlled by the light sensor on the DIC which talks to the BCM which in-turn controls the indicator's illumination. At night, when you either turn on the headlamp switch or the sentinel, the command is sent to the BCM to now take the illumination information from the dimmer control directly. If your background illumination isn't working at night, then I would start with the dimmer control.
Old Aug 20, 2007 | 02:21 PM
luis miguel alonso
I have just configured the dimmer higher. If the instrument lights fail more frequently than right now, I will replace the dimmer switck.
Old Aug 20, 2007 | 02:30 PM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
If your instrument lights fail when you turn on your lights, check your tail lights at the same time. If they are off you probably have a headlight switch going out. You can get around this if you have a headlight sentinel (option) by turning it on using the DIC. It's a temp fix to drive the car till you replace the headlight switch. Search headlight switch and you should be able to find the fix info.
Old Oct 19, 2007 | 03:41 AM
luis miguel alonso
Thanks you TOPLS90,
Following your instructions, I changed the headlight switch 15 days ago, and now it works right.
To Sometimes Instrument Panel Lights do not work.
