Brake Bleeding Sequence
Old Aug 19, 2007 | 09:29 PM
Glen5241's Avatar
Glen5241
Default Brake Bleeding Sequence
I have always known to bleed brakes from farthest to nearest to the master cyclinder. For example, start at right rear, then left rear, right front and finally to left front. I will be changing calipers soon and read in the service manual that bleeding should be done in this order, right rear, left front, left rear and then right front. Obviously, GM wants it done their way, but can someone tell me why? Also, would bleeding the old fashion way be ok? I have read that many people do bleed farthest to nearest. I just want to get it done the "correct" way. Thanks for the help.
Old Aug 19, 2007 | 09:32 PM
02MillenniumVette's Avatar
02MillenniumVette
When I changed out my calipers I bled them the old fashion way, farthest to the nearest. Im sure that the majority if not everyone on here does it that way.
Old Aug 19, 2007 | 09:33 PM
stormrider's Avatar
stormrider
I bleeded mine the old fashion way and everything went fine. Do yourself a favor and buy some speed bleeders, if you haven't done so already. I think Corvette Garage sells them.
Old Aug 19, 2007 | 09:37 PM
Bob CTS's Avatar
Bob CTS
Doing it the ole fashion way will work fine.
Old Aug 19, 2007 | 09:41 PM
Oldvetter's Avatar
Oldvetter
It has to do with the "ABS System" and there are two different methods.
The "ABS System" is located in the rear for 1997-1998 C5s and the correct brake sequence is Right Rear - Left Rear - Right Front - Left Front.
For all later models C5s, the "ABS System" is located in the engine compartment and the sequence is RR -LF - LR - RF. Your 2003 falls in this category.
Old Aug 19, 2007 | 09:47 PM
Glen5241's Avatar
Glen5241
Great reasoning for the change. I will go with the service manual order. Not to say others don't know what is what, just feel better with an explaination to the change. I have a Motive Pressure Tank. Most use it as just an air pressure tank without putting fluid in it, possible leaks. Any thoughts on this? I have thought about Speed Bleeder. So they do work really well?
Old Aug 19, 2007 | 10:07 PM
Great answer - never new that.
To Brake Bleeding Sequence
