I would like to know which car vette do you think is faster a 99-04 z06 or a stock c6.Both of the cars can produce about 400 horses so which car so you think would win in a race?
Z06's were only 01 to 04 by the way. I don't know the answer to your question although I suspect the C5 Z is the more performance oriented car, but I do know I would not trade my 03 Z for a C6. I parked directly behind one the other day in the same colour (Millenium Yellow) and the C5 Z is so much better looking. C6 looked like a Japanese Ferrari wannabe.
Mathematically speaking, the c5z is faster (02-04s at least). And generally, most times you see show the c5z to have a slight edge on the c6.
Realistically, when put side to side they'll be equal. The c5z has a better power to weight ratio, but with a slightly larger engine, I'd imagine the c6 would have a flatter torque curve. I could go on, but because this topic has already been beaten into the ground, I'll stop.
YellowZed.....don't mean to be picky but I believe the C6 is VELOCITY yellow. Our Z's are Millenium yellow. Millenium yellow is darker then the velocity yellow.
I agree with you on looks.
I believe the reason the C5Z is faster then a stock C6 is weight.
My brother and my sister and friend have C6's and I have a stock 04 Z06 and I rape them every time by a couple of car lenghts.Long live the c5z06 best car ever for the price.
yeah I've seen several videos of z51 6 speed C6's getting pulled by Z's stock versus stock
Also GM announced that their new ls3 based C6 will approach C5 Z performance levels. There was a post over in C6 GEN showing that the GM posted speed numbers are the same for the Z and LS3, but that the LS3 starts to pull ahead by a little from 130 mph up.
Ed
I think the 05's were Millenium, but I could be wrong?
