Six speed torque management?
Thanks,
Clayton from Las Vegas
Torque Management is the act of pulling timing when a calculated
"MAX TORQUE" value of the drivetrain is being breached. Please don't confuse TM will all the other systems on a C5.
Active handling and Traction control are different systems, and not to be confused with Torque Management.
torque management on the 6 speed C5 is never activated unless the abuse mode is invoked (which you couldn't do that if you tried).
Here's the truth: yep; there is a TM table in the 6 speed PCM program.
here's the rest of the story... it's never activated. Timing is never "pulled" from the 6 speed by the TM system because it calculates a torque maximum value will be breached (it's pulled for other reasons ... like knock sensor detection; but this is not the "Torque management" system).
Just bucause the TM table (in a 6 speed C5 pcm ) is altered by a programmer... doesn't mean anything changes in the operation of the car.
If I find a "4 wheel drive" activation table in the C5 PCM... does it then have 4wd ???
I personally keep stability control on, because it could save your butt if you start going sideways, but it could be causing what you're describing.
End result is now as long as I'm either set in comp mode or TC/AH off its all good, I can power shift and roast the tires if I really want to. But if both TC/AH are on it will fall on its face when the tires start to break loose.
HTH
