SAE vs. uncorrected numbers, question...
More info...
That is, the corrected readings are the same as the result that you would get by taking the car (or engine) to a certain temperature controlled, humidity controlled, pressure controlled dyno shop where they measure "standard" power, based on the carefully controlled temperature, humidity and pressure.
If you take your car to the dyno on a cold day at low altitude, it will make a lot of power. And if you take exactly the same car back to the same dyno on a hot day, it will make less power. But if you take the exact same car to the "standard" dyno (where the temperature, humidity and pressure are all carefully controlled) on those different days, it will always make exactly the same power.
Sometimes you may want to know how much power you are really making on that specific day due to the temperature, humidity and pressure on that day; in that case, you should look at the uncorrected power readings.
But when you want to see how much more power you have solely due to the new headers, or the new cam, then you will find that the corrected power is more useful, since it removes the effects of the temperature, humidity and atmospheric pressure and just shows you how much more (or less) power you have than in your previous tests.
There is no "right" answer... it's simply a matter of how you want to use the information.
If you want to know whether you are going to burn up the tranny with too much power on a cool, humid day, then go to the dyno and look at uncorrected power to see how exactly much power you have under these conditions.
But if you want to compare the effects due to modifications, or you want to compare several different cars at different times, then the corrected readings of the "standard" dyno will be more useful.
So lets say your SAE numbers are higher than your uncorrected(actual) numbers, could you still rightfully say that the SAE numbers is accurate power of the car?
I saw some guys packing ice on their intake manifolds so that they could brag about having higher horsepower than similar cars. Since the dyno doesn't know about the ice, it may produce HP numbers that look extra good, even with correction factors.
On a non-computer-controlled car, the correction factors are quite accurate. However, on a computer-controlled car, they are not so accurate, as the computer itself will vary the car's tuning for the climate conditions.
For example, let's say the dyno session is at 100F, which is hotter than SAE standard conditions. The car will very likely be running less timing at WOT than it would if you were at 68F. If you were to compare the SAE numbers for that car at 100F to the SAE numbers for a run at 68F, it's very likely that the 68F run will be higher, even though both are corrected to the same air density, due to the computer dialing in more timing.
With intercooled forced induction cars there's even more of a variance, because the correction factors don't take into account the altered efficiency of the intercooler in different outside air conditions.
We all use SAE to compare cars because that's the best we've got. but your car will still dyno higher SAE on a cold day. If you want to know "the best she'll do" you need to get a dyno session in the winter.
If someone thinks I have any of the above wrong, please post a correction.
