C5 shocks
Old Aug 24, 2007 | 08:30 AM
weisguy's Avatar
weisguy
Cruising
Default C5 shocks
I would like to know if there is A kit to install standard shocks in replacement for the electric system. I just do not have thousands to spend on shocks.
Old Aug 24, 2007 | 10:46 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Yes you can... You can replace the eletronic ones for standard ones.
Then you have to have a tech delete the ride control program from the PCM. Only reason I say a tech, is because they should have a TECH II programer... and last time I looked, they were about $3K.
Dave
Old Aug 24, 2007 | 10:52 AM
I can understand that. They certainly are not cheap come replacement time. Good luck if you go with the regular shocks.
Old Aug 24, 2007 | 11:03 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
You don't happen to have GMPP do you? Just had mine replaced
Old Aug 24, 2007 | 11:26 AM
steve8's Avatar
steve8
Sorry to hijack, but what were the circumstances in replacing under warranty? All 4 shocks?
Old Aug 24, 2007 | 02:08 PM
weisguy's Avatar
weisguy
Cruising
Dave, I called the local chevy dealership after your post and the shop manager said the ride control light would stay on and the active handling would be a problem. Is this someone that does not want to help or maybe just has never tried to delete the shocks?
Old Aug 25, 2007 | 12:03 PM
weisguy's Avatar
weisguy
Cruising
HELP anyone that might have a solution
Old Aug 25, 2007 | 01:18 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
What year Vette? I changed out my F45s on my 99 and got some resistors from Radio Shack for $4 and my computer believes my orginal shocks are installed and I changed them out for Koni FSD. 01 and newer they can be coded out and you will not have to do thr $4 mod, let me know if you need the procedures and I will pm them to you
Old Aug 25, 2007 | 01:28 PM
Kale's Avatar
Kale
DEtails? Gmpp says it doesnt cover shocks. I worry about mine.
To C5 shocks
