Guys
My driver turn signal was out, so I got to it by turning the headlights on, and reaching in and exchanging the bulb, but now my headlights are stuck in the up position, won't go down for anything.
I have to go on a trip tomorrow and don't want the lights stuck up
did you turn your switch back to automatic , have you got anything laying over the sensor on the dash , did you raise them by cranking the **** under the hood , if so did you return it to its original position ?
I raised them from inside, really didn't even touch them only squeezed my arm in to get to the turn signal bulb. I tried switching them off, but they just stay raised up.....
Alright, the headlights are up and will come on with the sensor or the switch, no problems there. But I have no dash lights or tail lights. What can I do? Can someone help? Could it be a fuse, I didn't touch the headlights while replacing the turn signal bulb (drivers side), I just turned them on as usual, without the car running so I would have a place to get my arm in.....
i forget what # fuse but u blew the tail light fuse......the reason the headlights arent going down and the dash lights arent working, is for safety reasons gm did that so u would know something is wrong.....same prob here good luck finding the fuse....
