Dip Stick Bolt
Old Aug 26, 2007 | 10:24 AM
Twin Screws's Avatar
Twin Screws
Default Dip Stick Bolt
Removed the dip stick bolt to install new plugs and wires (basically holds the dip stick tube against the engine block)...when I go to put the bolt back, it refuses to go back in...gets half way, and essentially stops...
my old man is a machinist and recommends using a shorter bolt...any implications if I do this?
Old Aug 26, 2007 | 12:21 PM
bb609's Avatar
bb609
Machinist huh? Ask him nicely and maybe he'll let you use his tap to chase the threads!
Old Aug 26, 2007 | 01:50 PM
z06Bigbird's Avatar
z06Bigbird
I have heard they are a bear to replace in other GM engines???
Old Aug 26, 2007 | 03:59 PM
tellefan's Avatar
tellefan
I had the same problem when I installed my headers. It was a hole for the header. I didn't want to force it. I bought a thread repair kit from Sears. It doesn't tap the threads, since doing that enlarges the hole. This kit cleans up the buggered up threads like a charm. Well worth the 49.00 I spent. It comes with both metric and american. David
To Dip Stick Bolt
